The Plustek 25 ppm SmartOffice PS283 offers you a flexible and productive way to scan and manage all of your paper based information. From business cards to legal size documents, they all can be scanned and saved as a searchable PDF at the touch of a button. The SmartOffice PS283 is suitable for any application requiring a small footprint, cost effective document scanner.
With the Plustek SmartOffice PS283, you can scan directly to searchable PDF and other common images files formats and then send your scanned documents to email, printer, folder or FTP site. All you have to do is press a button on the scanner! The SmartOffice PS283 also includes an industry standard TWAIN drivers, that allows the scanner to be used with thousands of document management and image enabled programs.
The Plustek SmartOffice PS283 scanner offers superior high resolution, up to 600 dpi for all your 24-bit color, grayscale, and black-and-white scanning needs. It matches your scanning budget and offers outstanding performance value in a compact footprint.
 - Plustek SmartOffice PS283 - document scanner - desktop - USB 2.0
 - Document scanner - desktop
- Interface Type
 - USB 2.0
- Scanning Sensor Type
 - Contact Image Sensor (CIS)
- Light Source
 - LED
- Additional Functions
 - Email, scan to print, scan to network share, scan to server
- Max Supported Document Size
 - 220 x 356 mm
- Localisation
 - United Kingdom
- Input Type
- Optical Resolution
 - 600 dpi x 600 dpi
- Max Document Scan Speed
 - 25 ppm (mono) / 5 ppm (colour)
- Max Document Size
 - 220 mm x 356 mm
- Supported Document Type
 - Plain paper, business card
- Document Feeder Type
 - Automatic
- Document Storage Capacity
 - 50 sheets
- Duty Cycle
 - 1500 scans per day
- System Requirements
 - Microsoft Windows 2000/XP/Vista/7/8
- Microsoft Certification
 - Compatible with Windows 7
 - 26.3 cm x 12.75 cm x 14.8 cm
 - 1.66 kg
- Environmental Standards
 - ENERGY STAR Qualified
- Interface Type
 - USB 2.0
 - 220 x 356 mm
- Localisation
 - United Kingdom
Scanner
- Input Type
 - 600 dpi x 600 dpi
- Scan Mode
 - Single-pass
- Bulb / Light Source Type
 - LED
- Max Document Scan Speed B/W
 - 25 ppm
- Max Document Scan Speed Colour
 - 5 ppm
- Control Panel Buttons Functions
 - Scan, file, Custom
- Duty Cycle
- Scanner Speed Details
 - 5 ppm - portrait (front) / colour (back) - A4 - 200 dpi , 25 ppm - portrait (front) / greyscale (back) - A4 - 200 dpi , 25 ppm - portrait (front) / black & white (back) - A4 - 200 dpi
- Scanner Features
 - Color Dropout, Blank Page Removal, automatic colour detection, Auto Crop, Auto Deskew, Auto Document Rotation, Auto Straighten, Auto Threshold
 - TWAIN
Media Handling
- Max Document Size
 - 220 mm x 356 mm
- Supported Document Size Details
 - ADF - up to A4 (210 x 297 mm)
 - Automatic
 - 50 sheets
 - USB 2.0
- ENERGY STAR Certified
- Power Device
 - External power adapter
- Software Included
 - Plustek DocAction, ABBYY FineReader 9.0 Sprint, Presto! BizCard 6, Presto! PageManager 9 SE
- OS Required
- System Requirements Details
 - Pentium 4 - 2 GHz - RAM 1 GB - HD 800 MB
 - 26.3 cm
 - 12.75 cm
 - 14.8 cm
 - 1.66 kg
