Brand
Plustek SmartOffice PS283
Quicklinx: BLGWWS00 Mfr#: 0220UK
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 220 x 356 mm
Interface: USB 2.0
Compatibility: PC
£178.49 ex VAT
£214.18 inc VAT
The Plustek 25 ppm SmartOffice PS283 offers you a flexible and productive way to scan and manage all of your paper based information. From business cards to legal size documents, they all can be scanned and saved as a searchable PDF at the touch of a button. The SmartOffice PS283 is suitable for any application requiring a small footprint, cost effective document scanner.
With the Plustek SmartOffice PS283, you can scan directly to searchable PDF and other common images files formats and then send your scanned documents to email, printer, folder or FTP site. All you have to do is press a button on the scanner! The SmartOffice PS283 also includes an industry standard TWAIN drivers, that allows the scanner to be used with thousands of document management and image enabled programs.
The Plustek SmartOffice PS283 scanner offers superior high resolution, up to 600 dpi for all your 24-bit color, grayscale, and black-and-white scanning needs. It matches your scanning budget and offers outstanding performance value in a compact footprint.
Plustek SmartOffice PS283 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Light Source
LED
Additional Functions
Email, scan to print, scan to network share, scan to server
Max Supported Document Size
220 x 356 mm
United Kingdom
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
25 ppm (mono) / 5 ppm (colour)
Max Document Size
220 mm x 356 mm
Supported Document Type
Plain paper, business card
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
1500 scans per day
Microsoft Windows 2000/XP/Vista/7/8
Microsoft Certification
Compatible with Windows 7
26.3 cm x 12.75 cm x 14.8 cm
1.66 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
220 x 356 mm
United Kingdom
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
25 ppm
Max Document Scan Speed Colour
5 ppm
Control Panel Buttons Functions
Scan, file, Custom
Duty Cycle
1500 scans per day
Scanner Speed Details
5 ppm - portrait (front) / colour (back) - A4 - 200 dpi , 25 ppm - portrait (front) / greyscale (back) - A4 - 200 dpi , 25 ppm - portrait (front) / black & white (back) - A4 - 200 dpi
Scanner Features
Color Dropout, Blank Page Removal, automatic colour detection, Auto Crop, Auto Deskew, Auto Document Rotation, Auto Straighten, Auto Threshold
TWAIN
Media Handling
Max Document Size
220 mm x 356 mm
Supported Document Size Details
ADF - up to A4 (210 x 297 mm)
Automatic
50 sheets
USB 2.0
ENERGY STAR Certified
External power adapter
Software Included
Plustek DocAction, ABBYY FineReader 9.0 Sprint, Presto! BizCard 6, Presto! PageManager 9 SE
System Requirements Details
Pentium 4 - 2 GHz - RAM 1 GB - HD 800 MB
26.3 cm
12.75 cm
14.8 cm
1.66 kg
Interface: USB 2.0
Compatibility: PC
Brand: Plustek
