SmartOffice PL1500 ADF document scanner, a new member of Smart Office series, offers high-speed scanning capability and compact design, making it a perfect solution for workgroups and other decentralized scanning applications.
SmartOffice PL1500 ADF scanner provides a maximum scanning speed of 15 pages per minute with optical resolution up to 1200 dpi. Auto Document Feeder (ADF) permits identify of large quantities of documents that holds up to 50 pages at one time.
Apart from ADF, it can be used as regular flatbed scanners which add even more versatility to satisfy all your needs. This SmartOffice PL1500 ADF scanner is a truly versatile document scanner that puts up outstanding value and high performance. It is well suited for business processes, corporate and SOHO use to achieve the highest level of productivity.
SmartOffice PL1500 ADF is idealistic for departmental or workgroup users, such as hospitals, law firms, CPA firms, banks and other financial institutions. This total solution document scanner is designed to provide maximum utility with minimum effort.
- Plustek SmartOffice PL1500 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Light Source
- Xe-gas cold cathode fluorescent lamp
- Max Supported Document Size
- 220 x 356 mm
- Localisation
- United Kingdom
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels) / 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 15 ppm (mono) / 8 ppm (colour)
- Max Document Size
- 216 mm x 356 mm
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 1500 scans per day
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows 2000/XP/Vista/7
- Microsoft Certification
- Compatible with Windows 7
- 46.8 cm x 34.7 cm x 17.5 cm
- 4.8 kg
- Interface Type
- USB 2.0
- 220 x 356 mm
- Localisation
- United Kingdom
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- CCD
- Bulb / Light Source Type
- Max Document Scan Speed B/W
- 15 ppm
- Max Document Scan Speed Colour
- 8 ppm
- Control Panel Buttons Functions
- Scan, copy, file, OCR, Custom
- Duty Cycle
- Scanner Speed Details
- 8 ppm - colour - A4 - 200 dpi , 15 ppm greyscale (back) - A4 - 200 dpi , 15 ppm - black & white - A4 - 200 dpi
- TWAIN
Media Handling
- Max Document Size
- 216 mm x 356 mm
- Plain paper
- Supported Document Size Details
- ADF - up to 220 x 356 mm , Flatbed - up to 216 x 297 mm
- Automatic
- 50 sheets
- USB 2.0 - Type B
- Included Accessories
- Automatic document feeder
- Cables Included
- 1 x USB cable
- FCC Class B certified, RoHS, WEEE
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Software Included
- ABBYY FineReader 6.0 Sprint Plus, Plustek DI Capture, Plustek DocAction, NewSoft Presto! PageManager 7.10
- OS Required
- System Requirements Details
- Pentium 4 - 2 GHz - RAM 512 MB - HD 800 MB
- 46.8 cm
- 34.7 cm
- 17.5 cm
- 4.8 kg
