Plustek PL806 Document Scanner
Quicklinx: 56V5WS00 Mfr#: PL806
The PL806 ADF document scanner, a member of Smart Office series, offers high-speed scanning capability and compact design, making it a perfect solution for workgroups and other decentralized scanning applications.
The PL806 ADF scanner provides a maximum scanning speed of 8 pages per minute, optical resolution up to 600 dpi, and permits identify of large quantities of documents at high speed by built-in Auto Document Feeder (ADF) that holds up to 50 pages.
Besides, it can be used as regular flatbed scanner easily, which adds ever more versatility to provide all your need. This PL806 ADF scanner is a truly versatile document scanner that puts up outstanding value and high performance, making it a perfect business and SOHO solution.
Plustek PL806 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CCD
Light Source
Xe-gas cold cathode fluorescent lamp
Max Supported Document Size
220 x 355.6 mm
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels)
Optical Resolution
600 dpi
Max Document Scan Speed
8 ppm (mono)
Max Document Size
220 mm x 355.6 mm
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Microsoft Windows XP Professional SP1, Microsoft Windows XP Home Edition SP1, Microsoft Windows 2000 SP4
Microsoft Certification
Certified for Windows Vista
4.8 kg
Interface Type
USB 2.0
220 x 355.6 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth
48-bit colour
Optical Resolution
600 dpi
CCD
Bulb / Light Source Type
Max Document Scan Speed B/W
8 ppm
Scanner Speed Details
8 ppm - greyscale - A4 - 200 dpi
TWAIN
Media Handling
Max Document Size
220 mm x 355.6 mm
Plain paper
Automatic
50 sheets
Interfaces Details
USB 2.0 - Type B
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
UL, TUV GS, C-Tick, cUL, CB, FCC
External power adapter
Software Included
Drivers & Utilities, Presto! ImageFolio, Presto! PageManager 6.0, ABBYY FineReader 6.0 Sprint Plus
Additional Requirements
CD-ROM, USB port
System Requirements Details
Pentium III - 1 GHz - RAM 256 MB - HD 800 MB
4.8 kg
