Plustek Opticslim OF120
Quicklinx: BLH6WS00 Mfr#: 0229UK
The OpticFilm 120 delivers the professional image quality results from 35 mm film strips, slides, and 120/220 film from 6 x 4.5 cm up to 6 x 12 cm in sizes. It is designed for professional photographers, advanced amateur photographers, film photo enthusiasts, photography schools and clubs. The OpticFilm 120 satisfies the film scanning requirements of advanced amateurs or professionals that require the ultimate in image quality and an ICC profiled scanning system.
  • Extraordinary image quality
    The outstanding image quality is assured by state of the art optical and electronic systems including an 8-element glass lens with 5300 dpi optical resolution, high-sensitive color CCD with 10600 dpi resolution, and stable light sources. Delivering an effective usable dynamic range of 4.01 and a theoretically maximum density of 4.8, providing accurate color and all highlight and shadow details.
  • Excellent designed film carriers ensure accurate imaging and efficient workflow
    The OpticFilm 120 includes patent-pending, adjustable pitch 120 film holders that ensure flat film for in-focus scans. Users do not need to cut 3-frame 6 x 7 120 film strips. The Opticfilm 120 also uses an automatic motorized film transport system that speeds the scanning workflow.
  • Elegant and compact design
    The OpticFilm 120's metal case provides isolation and stability for the lens, CCD and automatic transport assemblies. The OpticFilm 120 is one of the most compact 120 film scanners on the market. The rear cover design reduces the scanners overall dimensions and prevents dust from entering the scanner.
Plustek OpticFilm 120 - film scanner - desktop - USB 2.0
Film scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CCD
Light Source
LED
Max Supported Document Size
Film 120 (6 cm)
United Kingdom
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Optical Resolution
5300 dpi
Max Document Size
60 mm x 120 mm
Supported Document Type
Slides, film
Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Microsoft Windows Vista / XP / 7 / 8
21 cm x 37.4 cm x 18.9 cm
5.7 kg
Interface Type
USB 2.0
Film 120 (6 cm)
United Kingdom
Scanner
Input Type
Grayscale Depth
Colour Depth
48-bit colour
Optical Resolution
5300 dpi
CCD
Bulb / Light Source Type
LED
Scan Density Range
4.01D
Media Handling
Max Document Size
60 mm x 120 mm
Slides, film
USB 2.0
Software Included
SilverFast Ai Studio 8
System Requirements Details
2 GHz - RAM 2 GB - HD 10 GB
21 cm
37.4 cm
18.9 cm
5.7 kg
