Brand
Plustek OpticSlim 1180
Quicklinx: BLH5WS00 Mfr#: 0254UK
Type: Flatbed scanner
Form Factor: Desktop
Max Paper Size: 297 x 431.8 mm
Interface: USB 2.0
Compatibility: PC
11 in stock
£226.70 ex VAT
£272.04 inc VAT
The Plustek OpticSlim 1180 is an A3, tabloid sized scanner, designed for high quality scanning of art, photos, scrapbooks, genealogy research, newspaper, historical documents scrapbooks, documents, and other items up to 12 x 17" in size. OpticSlim 1180 includes four one-touch scan buttons to simplify and automate the most common scanning functions (i.e. scan, OCR, PDF and email). These features make it the ideal scanner for scrapbooking, genealogy, photo organizers, photo scanning, map scanning, historical document scanning, graphic designers, publishing companies, libraries, schools, small office/home office (SOHO) users and for those who require high quality large format scanning at a reasonable price.
  • Large format scanning
    Scanning of A3 tabloid size documents and graphics up to 1200 dpi make this scanner ideal for art, scrapbooking, photo scanning and genealogy!
  • Compact design
    With a sleek and compact design, the OpticSlim 1180 uses less desktop and storage space than other A3, tabloid scanners.
  • Easy to use
    Four one-touch buttons for performing pre-set jobs enables users to quickly: scan, email, OCR, or create PDF files.
  • LED light source
    The OpticSlim 1180's LED light source provides stable illumination that doesn't change from scan to scan or over the life of the scanner. This results in higher quality images and no warm-up time is needed.
  • Environmentally responsible and energy-saving
    The OpticSlim 1180 meets ENERGY STAR standards, and contributes to an environmentally-friendly and responsible work space.
Plustek OpticSlim 1180 - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Light Source
LED
Max Supported Document Size
297 x 431.8 mm
United Kingdom
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
Optical Resolution
1200 dpi
Scan Speed
15 sec / page (colour)
Max Document Size
297 mm x 431.8 mm
Duty Cycle
2500 scans per day
Microsoft Windows Vista / XP / 7 / 8
58.9 cm x 40.7 cm x 6.8 cm
4.32 kg
Interface Type
USB 2.0
297 x 431.8 mm
United Kingdom
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
48-bit colour
Optical Resolution
1200 dpi
Scan Mode
Single-pass
Bulb / Light Source Type
LED
Scan Speed
Control Panel Buttons Functions
Scan, email, OCR
Duty Cycle
2500 scans per day
TWAIN
Media Handling
Max Document Size
297 mm x 431.8 mm
Supported Document Size Details
Flatbed - up to 297 x 431.8 mm
USB 2.0
External power adapter
Software Included
Plustek DocAction, ABBYY OCR Software, Presto! PageManager 9
System Requirements Details
Windows XP/Vista/7/8 - Pentium 4 RAM 512 MB - HD 800 MB
58.9 cm
40.7 cm
6.8 cm
4.32 kg
Interface: USB 2.0
Compatibility: PC
Brand: Plustek
Stock Status: In stock
