Product
Plustek OpticPro A320 A3 Flatbed Scanner
Quicklinx: 636CWS00 Mfr#: A320
Plustek OpticPro A320 takes the pain out of large format scanning. It is USB 2.0 scanning device that can scan an A3 size document with high quality - resolution as high as 1600 dpi and scanning area as large as 12" x 17" (304.8 mm x 431.8 mm) - in just 11.2 seconds. Often, large format scanning is considered to be complex but Plustek OpticPro A320 makes is very easy for the end-user with its seven one-touch function buttons. What's more, it comes bundled with highly effective image processing and document management software for enhanced versatility. It provides for fast and secure PDF conversion, highly accurate optical character recognition (OCR) and easy sharing of files over a network.
Plustek OpticPro A320 has been specially designed for professionals who require best of both worlds - high quality results coupled with efficiency. It is ideal for graphic designers, publishing companies, libraries, schools, small office/home office (SOHO) users and for those who require to do large format scanning regularly like hospitals, law firms, financial institutions etc.
Plustek OpticPro A320 - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Light Source
Xe-gas cold cathode fluorescent lamp
Max Supported Document Size
304.8 x 431.8 mm
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
1600 dpi x 1600 dpi
Scan Speed
11.2 sec / page
Max Document Size
304.8 mm x 431.8 mm
Document Feeder Type
Manual
Microsoft Windows Vista / 2000 / XP
Microsoft Certification
Compatible with Windows 7
62.3 cm x 40 cm x 13 cm
7.5 kg
Interface Type
USB 2.0
304.8 x 431.8 mm
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
1600 dpi x 1600 dpi
Scan Mode
Single-pass
Scan Element Type
CCD
Bulb / Light Source Type
Scan Speed
11.2 sec / page
Control Panel Buttons Functions
Scan, copy, email, file, PDF/OCR
Scanner Speed Details
11.2 sec/scan - colour - A3 - 300 dpi , 11.2 sec/scan - greyscale - A3 - 300 dpi , 11.2 sec/scan - black & white - A3 - 300 dpi
TWAIN
Media Handling
Max Document Size
304.8 mm x 431.8 mm
Manual
USB 2.0
1 x USB cable
C-Tick, BSMI, CB, FCC, C-ETL, ETL
External power adapter
Power Consumption Operational (Standby)
36 Watt (4 Watt)
Software Included
Drivers & Utilities, ABBYY FineReader 6.0 Sprint Plus, NewSoft MaxReader, Plustek DI Capture, Plustek DocAction, NewSoft Presto! ImageFolio 4.5, NewSoft Presto! PageManager 7.10
Additional Requirements
CD-ROM, graphics card, USB port
System Requirements Details
Pentium 4 - 2 GHz - RAM 512 MB - HD 800 MB
62.3 cm
40 cm
13 cm
7.5 kg
