Plustek OpticFilm 8200i Ai is a powerful scanner with 7200 dpi resolution. Its sharp optical system produces excellent detail in shadow areas and remarkable tonal range. A built-in infrared channel helps users remove dust and scratches on the original negatives and slides without additional post-processing. With the IT 8 calibration slide, this powerful scanner consistently delivers accurate colors and detail.
The Plustek OpticFilm 8200i Ai gets professional quality results from any photographic original. It is used by professional photographers, amateur photographers, graphic designers, image enthusiasts, and those who highly demand image quality on photo enlargements.
- Plustek OpticFilm 8200i Ai - film scanner (35 mm) - desktop - USB 2.0
- Film scanner (35 mm) - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Light Source
- LED
- Max Supported Document Size
- Film 135 (35mm)
- Localisation
- United Kingdom
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels) / 48-bit colour
- Grayscale / Color Depth (External)
- Optical Resolution
- 7200 dpi x 7200 dpi
- Max Document Size
- 36.8 mm x 25.4 mm
- Supported Document Type
- Slides, film
- System Requirements
- Apple MacOS X 10.6, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5, Apple MacOS X Lion 10.7, Windows 8, Apple OS X 10.8 Mountain Lion
- Microsoft Certification
- Compatible with Windows 7
- 12 cm x 27.2 cm x 11.9 cm
- 1.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- Film 135 (35mm)
- Localisation
- United Kingdom
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 48-bit colour
- Scan Mode
- Single-pass
- CCD
- Bulb / Light Source Type
- LED
- Scan Density Range
- 3.6D
- Scanner Speed Details
- 8 sec/scan - film (negatives) - preview - 35mm , 8 sec/scan - film (positives) - preview - 35mm , 36 sec/scan - film (negatives) - final - 3600 dpi , 113 sec/scan - film (negatives) - final - 7200 dpi
- Scanner Features
- Multi-Sampling, hardware Multi-Exposure for negative film, iSRD (Infrared Smart Removal of Defect)
- TWAIN
Media Handling
- Max Document Size
- 36.8 mm x 25.4 mm
- Slides, film
- Interfaces Details
- USB 2.0 - Type B
- ENERGY STAR Certified
- Power Device
- External power adapter
- Software Included
- Plustek Quick Scan, SilverFast Ai Studio 8
- OS Required
- System Requirements Details
- Windows XP/Vista/7/8 - Pentium - 2 GHz - RAM 2 GB - HD 10 GB , MacOS X 10.5 or later - Pentium - 2 GHz - RAM 2 GB - HD 10 GB
- 12 cm
- 27.2 cm
- 11.9 cm
- 1.6 kg
