Plustek OpticFilm 8100 is a dedicated and versatile film scanner with 7200 dpi optical resolution. Its light sources give images more precise color rendering with less power consumption. Two one-touch buttons make scanning easier and more efficient for sharing on websites such as Flickr, Facebook, Picasa, etc.
Compared with the conventional flatbed scanners, the Plustek OpticFilm 8100 provides a much smaller footprint. The scanner is about the same size as a loaf of bread and takes less space on one's desktop. The custom carrying bag can be used for transportation or storage.
With the Plustek OpticFilm 8100 it is easier than ever to get started. It is the ideal film scanner for a wide range of users, including home users, lomographers, small office/workshop users, amateur photographers and photographers.
- Plustek OpticFilm 8100 - film scanner (35 mm) - desktop - USB 2.0
- Film scanner (35 mm) - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Light Source
- LED
- Max Supported Document Size
- Film 135 (35mm)
- Localisation
- United Kingdom
- Input Type
- Grayscale / Color Depth
- 48-bit colour
- Optical Resolution
- 7200 dpi x 7200 dpi
- Max Document Size
- 36.8 mm x 25.4 mm
- Supported Document Type
- Slides, film
- System Requirements
- Apple MacOS X 10.6, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5, Apple MacOS X Lion 10.7
- Microsoft Certification
- Compatible with Windows 7
- 12 cm x 27.2 cm x 11.9 cm
- 1.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- Film 135 (35mm)
- Localisation
- United Kingdom
Scanner
- Input Type
- Colour Depth
- 48-bit colour
- Scan Mode
- Single-pass
- CCD
- Bulb / Light Source Type
- LED
- Scanner Speed Details
- 8 sec/scan - film (negatives) - preview - 35mm , 8 sec/scan - film (positives) - preview - 35mm , 36 sec/scan - film (negatives) - final - 3600 dpi , 113 sec/scan - film (negatives) - final - 7200 dpi
- Scanner Features
- Multi-Sampling, hardware Multi-Exposure for negative film
- TWAIN
Media Handling
- Max Document Size
- 36.8 mm x 25.4 mm
- Slides, film
- USB 2.0 - Type B
- Included Accessories
- Carrying case, 2 film holders
- ENERGY STAR Certified
- Power Device
- External power adapter
- Software Included
- Plustek Quick Scan, SilverFast SE Plus 8
- OS Required
- 12 cm
- 27.2 cm
- 11.9 cm
- 1.6 kg
