Plustek MobileOffice S410
Quicklinx: BLGTWS00 Mfr#: 0223UK
Type: Sheetfed scanner
Form Factor: Portable
Max Paper Size: 216 x 910 mm
Interface: USB 2.0
Compatibility: PC
£95.76 ex VAT
£114.91 inc VAT
Designed with the reliability demanded by business users, and a price point attractive to home users, the USB powered MobileOffice S410 scanner and document management solution will convert paper documents, rigid embossed cards, expense reports, business cards and more to searchable PDF with the touch of a button at a FAST 6 page per minute scan speed!
The MobileOffice S410 can scan documents to Evernote and photos to Google Picasa by simply pressing a button! DocAction single touch scanning and industry standard TWAIN drivers ensure compatibility with thousands of scanning and imaging programs including: document management, healthcare ERM, financial, and thousands of other image enabled applications. These features make the MobileOffice S410 a powerful document management solution to meet any requirement.
The MobileOffice S410 also features advanced image processing that allows you to scan mixed sized documents with no adjustments. Images are automatically straightened, rotated and adjusted for exposure. The result is more accurate Optical Character Recognition (OCR) and Business Card Recognition (BCR) which fewer pages that need to be rescanned. Step up features from the MobileOffice S400: faster 6 ppm scan speed, embossed card scanning, higher daily duty cycle rating.
Plustek MobileOffice S410 - sheetfed scanner - portable - USB 2.0
Sheetfed scanner - portable
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Max Supported Document Size
216 x 910 mm
United Kingdom
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Scan Speed
6 ppm
Max Document Size
216 mm x 910 mm
Supported Document Type
Plain paper, plastic card
Microsoft Windows 2000/XP/Vista/7
Microsoft Certification
Compatible with Windows 7
29.5 cm x 5 cm x 4.05 cm
410 g
Interface Type
USB 2.0
216 x 910 mm
United Kingdom
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Scan Speed
6 ppm
Control Panel Buttons Functions
Scan, Scan-to-PDF
Scanner Speed Details
9 sec/scan - colour - A4 - 300 dpi
Scanner Features
Powered by USB port
TWAIN
Media Handling
Max Document Size
216 mm x 910 mm
USB 2.0
Software Included
Plustek DI Capture, Plustek DocAction, HotCard BizCard Finder 3.0, ABBYY FineReader 9.0 Sprint, Plustek DocTWAIN, Plustek DI Express 6
System Requirements Details
Pentium III - 1 GHz - RAM 256 MB - HD 800 MB
29.5 cm
5 cm
4.05 cm
410 g
Interface: USB 2.0
Compatibility: PC
Brand: Plustek
