Plustek's eScan A150 allows end users to instantly power up the device for fast scanning. Its built-in 7" LCD touch screen is intuitive and offers a quick way to review or even crop targeted images, before delivering the final digitally captured data.
                Setup easilyeScan works as easy as an appliance. End users can just plug the network cable and turn it on to start. There is no need for IT staff setup and training. Just respond to the three easy intuitive steps on the large seven inch LCD screen and you are on your way.
                ScanA Big eScan button is always waiting for your touch. If you have other requirements simply change the scan setting; it's done!
                VieweScan allows you to validate the scanned images in the thumbnail mode. It also allows you to review each individual page in full page mode to crop, rotate, or even redact the page. If you are happy with the scanned thumbnail image, you are ready to deliver!
                SaveeScan is loaded with 9 destinations to choose from: USB drive, network folder, mobile, eMail address, or variety of cloud (Dropbox, Google Drive, Evernote, Box, SharePoint or FTP). Once a destination is selected just enter your credentials, cheers!
                Sending to multiple destinationsFrom time to time you may want to send same document to different destinations. The eScan allows you to send the same scanned document over and over again.
- Plustek eScan A150 - document scanner - desktop - USB 2.0, LAN
- Document scanner - desktop
- Interface Type
- USB 2.0, LAN
- Scanning Sensor Type
- Dual CIS
- Light Source
- LED
- Additional Functions
- Email, scan to network share, scan to cloud, scan to smart devices, scan to USB, scan to FTP
- Max Supported Document Size
- 244 x 356 mm
- Localisation
- United Kingdom
- Input Type
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 15 ppm (mono) / 4 ppm (colour)
- Max Document Size
- 216 mm x 356 mm
- Automatic Duplexing
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 1500 scans per day
- Flash Memory
- 1 GB
- Microsoft Certification
- Compatible with Windows 7
- 31.8 cm x 17 cm x 18.9 cm
- 2.8 kg
- Interface Type
- USB 2.0, LAN
- 244 x 356 mm
- Localisation
- United Kingdom
Scanner
- Input Type
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- Dual CIS
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 15 ppm
- Max Document Scan Speed Colour
- 4 ppm
- Duty Cycle
- Scanner Speed Details
- 15 ppm - duplex - greyscale - A4 - 200 dpi , 15 ppm - duplex - black & white - A4 - 200 dpi , 4 ppm - duplex - colour - A4 - 200 dpi , 30 ipm - duplex - greyscale - A4 - 200 dpi , 30 ipm - duplex - black & white - A4 - 200 dpi , 8 ipm - duplex - colour - A4 - 200 dpi
- Scanner Features
- 7" touch screen TFT display
Media Handling
- Max Document Size
- 216 mm x 356 mm
- Automatic
- 50 sheets
- Flash Memory
- 1 GB
- USB 2.0 , LAN
- Power Device
- External power adapter
- 31.8 cm
- 17 cm
- 18.9 cm
- 2.8 kg
- 5 °C
- 35 °C
