Plustek eScan A150
Plustek eScan A150
Quicklinx: BLH7WS00 Mfr#: 0263UK
Plustek's eScan A150 allows end users to instantly power up the device for fast scanning. Its built-in 7" LCD touch screen is intuitive and offers a quick way to review or even crop targeted images, before delivering the final digitally captured data.
  • Setup easily
    eScan works as easy as an appliance. End users can just plug the network cable and turn it on to start. There is no need for IT staff setup and training. Just respond to the three easy intuitive steps on the large seven inch LCD screen and you are on your way.
  • Scan
    A Big eScan button is always waiting for your touch. If you have other requirements simply change the scan setting; it's done!
  • View
    eScan allows you to validate the scanned images in the thumbnail mode. It also allows you to review each individual page in full page mode to crop, rotate, or even redact the page. If you are happy with the scanned thumbnail image, you are ready to deliver!
  • Save
    eScan is loaded with 9 destinations to choose from: USB drive, network folder, mobile, eMail address, or variety of cloud (Dropbox, Google Drive, Evernote, Box, SharePoint or FTP). Once a destination is selected just enter your credentials, cheers!
  • Sending to multiple destinations
    From time to time you may want to send same document to different destinations. The eScan allows you to send the same scanned document over and over again.
Plustek eScan A150 - document scanner - desktop - USB 2.0, LAN
Document scanner - desktop
Interface Type
USB 2.0, LAN
Scanning Sensor Type
Dual CIS
Light Source
LED
Additional Functions
Email, scan to network share, scan to cloud, scan to smart devices, scan to USB, scan to FTP
Max Supported Document Size
244 x 356 mm
United Kingdom
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
15 ppm (mono) / 4 ppm (colour)
Max Document Size
216 mm x 356 mm
Automatic Duplexing
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
1500 scans per day
Flash Memory
1 GB
Microsoft Certification
Compatible with Windows 7
31.8 cm x 17 cm x 18.9 cm
2.8 kg
Interface Type
USB 2.0, LAN
244 x 356 mm
United Kingdom
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Dual CIS
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
15 ppm
Max Document Scan Speed Colour
4 ppm
Duty Cycle
1500 scans per day
Scanner Speed Details
15 ppm - duplex - greyscale - A4 - 200 dpi , 15 ppm - duplex - black & white - A4 - 200 dpi , 4 ppm - duplex - colour - A4 - 200 dpi , 30 ipm - duplex - greyscale - A4 - 200 dpi , 30 ipm - duplex - black & white - A4 - 200 dpi , 8 ipm - duplex - colour - A4 - 200 dpi
Scanner Features
7" touch screen TFT display
Media Handling
Max Document Size
216 mm x 356 mm
Automatic
50 sheets
Flash Memory
1 GB
USB 2.0 , LAN
External power adapter
31.8 cm
17 cm
18.9 cm
2.8 kg
5 °C
35 °C
