Plextor 128GB PX-128M6M mSATA 6GB/s Solid State Drive
Quicklinx: 9SDMWS00 Mfr#: PX-128M6M
The Plextor M6M is a high-performance mSATA 6 Gb/s SSD specifically engineered to give ultrabook, tablet PC, and other JEDEC MO-300 form factor users the speed and low power consumption benefits of the newest generation SSD technology.
  • High-performance
    The combination of the Marvell 88SS9188 controller and True Speed technology creates M6M the enhanced performance and reliability. The True Speed high-performance technology delivers real world benefits and prevents SSD speed drop, automatically returning performance to like-new speeds.
  • Enterprise-grade double-data protection
    Plextor SSD has a unique True protect protection system to protect the integrity of your data. To confirm that each piece of data is correctly stored with one hundred percent accuracy the 128-bit error correction code is used. For data confidentiality, the drive uses hardware in the US Government AES-validated Marvell controller to provide secure 256-bit full-drive encryption.
  • High energy efficiency with DEVSLP support
    It supports the SATA device sleep standard incorporating the DEVSLP state allowing the SSD to communicate in sleep mode. With the DEVSLP mode, the M6M can reduce the power consumption to only 2 MW, and resumes from DEVSLP mode only in 100 ms.
  • Extreme reliability
    Plextor SSDs are required to pass some of the toughest tests in the industry before even start production. Parallel tests involving 465 SSDs tested for more hours and the use of top grade FLEXSTAR testing equipment to simulate extreme operating environments ensure that the M6M is built and tested for the highest level of stability in any working condition.
  • Design for ultrabook
    With its ultra mini size, light weight and low power consumption, the M6M is especially suitable for ultra portable on-the-go computing device.
Plextor M6M PX-128M6M - SSD - 128 GB - SATA 6Gb/s
Solid state drive - internal
128 GB
Hardware Encryption
mSATA
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), TRIM support, hardware encryption, Plextor True Speed technology, S.M.A.R.T., 256-bit AES, JEDEC MO-300
29.8 mm x 50.8 mm x 3.6 mm
10 g
3-year warranty
128 GB
Hardware Encryption
mSATA
SATA 6Gb/s
29.8 mm
50.8 mm
3.6 mm
10 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
520 MBps (read) / 340 MBps (write)
4KB Random Read
90000 IOPS
4KB Random Write
76000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 52 pin mini-SATA
Compatible Bay
mSATA
Apple MacOS, Linux, Microsoft Windows
UL, TUV, VCCI, C-Tick, BSMI, CB, FCC, RoHS, KCC
Limited warranty - 3 years
70 °C
Shock Tolerance
1500 g @ 1ms
Vibration Tolerance
2.17 g @ 7-800 Hz (non-operating)
