Playseat Trophy Gaming Chair
Quicklinx: H9KDWS00 Mfr#: RAP.00304
Type: Gaming Chair
More than 50 In Stock
£440.84 ex VAT
£529.00 inc VAT
For ultimate immersion and customization. Change seat positioning to suit any racing style. Get an unparalleled sim racing performance at home with durable, lightweight, high-carbon steel frame and patented body-conforming Actifit seat technology.
REVOLUTIONARY DESIGN. UNRIVALED DURABILITY.
A new standard has been set. Get the ultimate immersive racing experience with a groundbreaking patented design. Extreme rigidity comes from a lightweight carbon frame. Long-lasting durability is achieved with powder coating finish, high-grade steel alloys, anodised aluminum parts—plus PU leather. Whether at home or in competitions, Playseat Trophy - Logitech G Edition changes the game and supports the full range of Logitech G Wheel and Pedal gear
INNOVATIVE ACTIFIT MATERIAL
Playseat’s Innovative ActiFit material comfortably conforms to your body, giving you the best support possible, so you can feel the full input from your Logitech G racing gear. ActiFit material also dissipates heat so you can race for long stints without overheating.
ULTIMATE FLEXIBILITY
Fully adjustable so you can put the wheel and pedal right where you want them. Tilt forward and backward, and move up or down. Racers of any age, shape and size will feel secure and ready to race.
Open cockpit design enables free body movement for optimal wheel and pedal performance. Backrest reclines separately with fully adjustable lumbar support. Seat can be softer or more firm depending on your preference.
The pedal and steering plates feature unique movement to accommodate a wide variety of racing styles. All adjustments bolt down to be completely rigid and tolerance free.
LIGHTWEIGHT & EASY TO STORE
The Playseat Trophy - Logitech G Edition’s carbon steel frame is strong, and exceptionally lightweight. At 37 lbs (17 kg), it’s one of the lightest chairs on the market. The Trophy’s design and weight is ideal for easy storage when not in use.
Logitech G PRO Wheel and Pedals sold separately
  • Frameless structure
    The Playseat Trophy is the first product to feature Playseat's frameless structure, a frameless but extremely stable seating structure in which the seat adapts itself naturally to the body of the racer, it allows all users to experience the highest levels of comfort for all ages and sizes, giving the real racing experience as you can find in real bucket seats. The technology also enhances the feel throughout your body, allowing you to be able to pick up on any true force feedback signals with all your senses.
  • Comfortable sitting position
    The unique and patented integrated design features maximum performance, quality, and comfort into the Playseat Trophy. Its cover is made out of breathable Playseat ActiFit material, allowing for many hours of racing without sweating.
  • Compatible with Direct Drive wheels
    The open cockpit design of the Playseat Trophy is made out of various steel alloys and space-grade aluminum details, making this racing seat as light as possible and enhancing the optimization for Direct Drive wheelbases. It will also allow full freedom with your legs for executing techniques like heel-and-toe.
  • Fully adjustable
    The Playseat Trophy is fully customizable, so it is possible to adjust the seat height, backrest, seat hardness, bucket seat feeling, pedal plate and steering wheelbase. So you can find your perfect racing position. The sitting position is easily adjustable and supports all ages, from children to adults.
Playseat Trophy - racing simulator cockpit - alloy steel, ActiFit, space-grade aluminium - black
Racing simulator cockpit
Gaming
Headrest
Assembly Required
Material
Alloy steel, ActiFit, space-grade aluminium
58 cm
138 cm
101 cm
16 kg
2 years
Gaming
Headrest
Max Load Weight
122 kg
Material
Assembly Required
Breathable, adjustable steering wheel plate, adjustable pedal plate, compatible with all steering wheels and pedals, frameless structure
Seat
Adjustable Height
Bucket style, adjustable hardness
Backrest
Angle Adjustment
58 cm
138 cm
101 cm
16 kg
2 years
Type: Gaming Chair
Brand: Playseat
