Playseat Trophy - Logitech G Edition
Quicklinx: HX38WS00 Mfr#: G.00320
£432.85 ex VAT
£519.42 inc VAT
Tune your driver's seat and lock into the thrill of racing.
  • Revolutionary design, unrivaled durability
    Get the ultimate immersive racing experience with a groundbreaking patented design. Extreme rigidity comes from a lightweight carbon frame. Long-lasting durability is achieved with powder coating finish, high-grade steel alloys, anodized aluminum parts - plus PU leather. Whether at home or in competitions, Playseat Trophy - Logitech G Edition changes the game and supports the full range of Logitech G Wheel and Pedal gear.
  • Innovative ActiFit material
    Playseat's Innovative ActiFit material comfortably conforms to your body, giving you the best support possible, so you can feel the full input from your Logitech G racing gear. ActiFit material also dissipates heat so you can race for long stints without overheating.
  • Ultimate flexibility
    Fully adjustable so you can put the wheel and pedal right where you want them. Tilt forward and backward, and move up or down. Racers of any age, shape and size will feel secure and ready to race. Open cockpit design enables free body movement for optimal wheel and pedal performance. Backrest reclines separately with fully adjustable lumbar support. Seat can be softer or more firm depending on your preference. The pedal and steering plates feature unique movement to accommodate a wide variety of racing styles. All adjustments bolt down to be completely rigid and tolerance-free.
  • Lightweight and easy-to-store
    The Playseat Trophy - Logitech G Edition's carbon steel frame is strong, and exceptionally lightweight. The Trophy's design and weight is ideal for easy storage when not in use.
  • PRO dreams - materialized
    Logitech G PRO Wheel and Pedals were designed in collaboration with professional real-world and sim racers. The result is meticulously honed equipment perfectly balanced for performance.
Playseat Trophy Logitech G Edition - racing simulator cockpit - alloy steel, ActiFit, space-grade aluminium - grey
Racing simulator cockpit
Gaming
Headrest
Assembly Required
Material
Alloy steel, ActiFit, space-grade aluminium
Grey
138 cm
58 cm
101 cm
16 kg
2 years
Gaming
Headrest
Max Load Weight
122 kg
Max User Height
220 cm
Material
Grey
Assembly Required
Breathable, adjustable steering wheel plate, adjustable pedal plate, compatible with all steering wheels and pedals, frameless structure
Seat
Adjustable Height
Bucket style, adjustable hardness
138 cm
58 cm
101 cm
16 kg
2 years
Brand: Playseat
