Playseat Evolution Pro Black Actifit
Quicklinx: HC13WS00 Mfr#: REP.00262
Type: Gaming Chair
Hurry, only 3 left in stock!
£232.50 ex VAT
£279.00 inc VAT
Come closer. You’ve got to inspect the Playseat Evolution PRO upclose to appreciate how close the designers have come to perfection here. To feel like you’re on a race track when you’re in your gaming room? That’s hard. You know this chair. We’ve just improved on our already legendary Playseat Evolution. You can taste the champagne on the podium just a bit more as this is as close to the real-race feeling as it gets. The racing cockpit has head stabilisers in the exact place they need to be in. It’s so easy to adjust the pedal plate and steering wheel plate, you could do it blindfolded (not recommended though). The only problem we foresee is a personal one. This chair is tough to share. You sit in it. You own it. We’ll leave that for you to deal with.
Key Features
  • Developed in cooperation with professional racing drivers
  • Authentic racing simulator cockpit with GTR sitting position
  • It’s Equipped with head stabilisers like in the real deal
  • Superior build quality, stability, and comfort
  • It’s fully adjustable to fit all drivers (children, teens and adults)
  • Adjustable steering plate and pedal plate
  • Easy-to-store thanks to its patented foldable design
  • Quick-and-easy to assemble
  • Sturdy construction
    The carbon steel base provides stability and strength, ensuring that the cockpit remains secure even during thrilling racing simulations.
  • User-friendly adjustments
    Features adjustable steering wheel and pedal plates to cater to individual preferences, creating a comfortable and customized racing experience.
  • Space-saving design
    The foldable feature allows for easy storage in smaller spaces, ideal for gamers with limited room without compromising on quality.
  • Safety assurance
    Incorporates head and neck safety technology, providing peace of mind during intense racing sessions.
  • Broad compatibility
    Seamlessly compatible with all steering wheels and pedals, offering flexibility to adapt to various racing setups.
Playseat Evolution Pro ActiFit - racing simulator cockpit
Racing simulator cockpit
Assembly Required
50 cm
130 cm
98 cm
21 kg
2 years
Max Load Weight
120 kg
Max User Height
2.2 m
Assembly Required
Foldable, compatible with all steering wheels and pedals, adjustable pedal plate, adjustable steering wheel plate, head and neck safety technology
Base
Material
Carbon steel
50 cm
130 cm
98 cm
21 kg
Shipping Width
50.5 cm
Shipping Depth
60.5 cm
Shipping Height
40 cm
Shipping Weight
22.5 kg
2 years
Type: Gaming Chair
Brand: Playseat
