The sophisticated, performance driven Plantronics Voyager Edge Bluetooth headset is an inspired blend of elegance, comfort, and signature Plantronics audio technology. Voice commands and smartphone assistant integration keep you in control, audio alerts keep you informed, premium noise canceling keeps calls clear in any environment, and a portable charging case keeps Voyager Edge ready when you are.
Charges on the go
Thanks to the included charging case, you'll add up to 10 more hours of talk time to your Voyager Edge for up to a total of 16 hours of talk time. It's easy to check the battery level of your headset or case - just swipe your finger over the icons on the case to see the status indicator. -
Eliminates disruptive noise
With three precisely tuned microphones and enhanced noise canceling, the Voyager Edge will optimize your voice and minimize noise caused by wind, movement, and background sounds so your caller hears you, not your surroundings. Additionally, this headset supports wideband audio, making it compatible with smartphones enabled for HD Voice. -
Responds to your needs
The Voyager Edge includes responsive smart sensor technology that can redirect calls to your phone or headset, pause music for incoming calls, and automatically answer calls as you place the headset on your ear. It also syncs to your contacts so you can hear who's calling without having to look at your smartphone. Voice commands make call management easy - simply say "Answer" to take the call, or "Ignore" to send it to voicemail. -
Moisture-resistant
You can rely on the Voyager Edge to work as hard as you do, through rainy days and the inevitable coffee spill. Protected against moisture damage by P2i technology, the nano-coating is applied during the manufacturing process, resulting in invisible liquid repellent properties that makes the headset more reliable, wherever your busy life takes you.
- Poly Voyager Edge UC B255 - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics, computer
- Headphones Form Factor
- Ear-bud
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0
- Sound Output Mode
- Mono
- Microphone
- Boom
- Controls
- On/off
- 2-year warranty
- Product Type
- 9 g
- Recommended Use
- Max Operating Distance
- 10 m
Audio Output
- Ear-bud
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
- Sound Output Mode
- Mono
Microphone
- Boom
Remote Control
- Controls
- On/off
Wireless Link
- Transmission Range
- 10 m
- Connector Type
- USB (5 pin Micro-USB Type B)
- Included Accessories
- Bluetooth USB adapter, charging case
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 6 hour(s)
- Standby Time
- 168 hours
- Limited warranty - 2 years
