Poly Plantronics PSP EHS Cable for Savi and CS Range 2.5mm to 2.5mm
Quicklinx: 854FWS00 Mfr#: 84757-01
Complement your Plantronics CS500 or W700 series wireless office system by using an electronic hook switch for remote call answering and call ending.
Compatible with the Following Panasonic Telephones:
  • KX-UT133
  • KX-UT136
  • KX-UT670
  • KX-UT248
Electronic Hook Switch- communicates electronically with the phone
Eliminates the need for a HL10 lifter
Enables One Touch Remote Call/Answer with Plantronics Headsets
Poly Panasonic PSP EHS Cable - headset cable
Cable
Headset cable
Savi W740, W740-M
Cable Type
Headset cable
Poly Savi W740, W740-M
