The perfect companion for your smartphone
The Plantronics® Marque 2™, a perfect companion for smartphones, now features DeepSleep™ power-saving mode and dual microphones that reduce noise and wind for clear, crisp call quality. For added convenience, there's even a dual charger for simultaneously charging your headset and phone from either your computer or car. Simply check the on-screen battery meter on your iPhone or Android™ smartphone. You can also listen to music or stream audio and Internet radio, and you can manage your calls without pressing buttons - just say "Answer" or "Ignore".
Bluetooth 3.0
Dual microphones for improved noise and wind noise reduction
DSP and echo noise reduction
Multipoint technology
Voice alerts for connection, battery life and volume
Answer/ignore voice recognition
DeepSleep mode allows up to 180 days (6 months) of battery life
Universal fit ear gel
Wideband audio support
Headset battery meter for iPhone and iPad
2-in-1 car charger also charges smartphone
Listen to music, GPS, and more
On-screen headset battery meter
- Poly - Plantronics Marque 2 M165 - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics
- Localisation
- Middle East, Africa, Europe
- Black
- Headphones Form Factor
- Ear-bud - over-the-ear mount - monaural
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0
- Sound Output Mode
- Mono
- Microphone
- Built-in
- Controls
- Volume
- 1-year warranty
- Product Type
- 7 g
- Black
- Recommended Use
- Localisation
Audio Output
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP)
- Sound Output Mode
- Mono
Remote Control
- Controls
- Volume
- Connector Type
- USB
- Included Accessories
- Earloop, ear tips kit
- Cable Details
- USB cable
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 7 hour(s)
- Standby Time
- 264 hours
- Limited warranty - 1 year
