Product
Plantronics HW261A Binaural Voicetube Headset
Quicklinx: 7SPGWS00 Mfr#: 36830-41
Recommended Use: Phone, Phone
Connectivity: Wired
Earcover : Binaural
Stock Status: In Stock, Used Stock
More than 50 in stock
£86.26 ex VAT
£103.51 inc VAT
Standard delivery Delivered within 3-5 working days
Working with the latest in wideband VoIP technology, the Plantronics SupraPlus Wideband headset delivers the highest level of audio performance even in noisy environments. The SupraPlus Wideband helps overcome the challenges posed by traditional technology, delivering heightened speech clarity and life-like fidelity. Users will experience greater satisfaction through enhanced intelligibility and reduced miscommunication. Designed for over-the-head comfort, the SupraPlus Wideband lets users choose between experiencing total-focus sound reduction (Binaural design) or conversing easily with coworkers without removing the headset (Monaural design).
Plantronics SupraPlus HW261/A - headset
Headset - wired
Recommended Use
Phone
Headphones Form Factor
On-ear
Wired
Microphone
Boom
Headset
74 g
Recommended Use
Phone
Headphones
Supraaural
Wired
Microphone
Boom
Connector Type
Headset (Quick Disconnect)
Headset cable
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 7SPG 040119
Condition: Customer return - item has been repaired under warranty by the manufacturer
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £62.34
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Connectivity: Wired
Earcover : Binaural
Brand: Plantronics
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
