Plantronics GameCom 780 Gaming Headset
Quicklinx: 7ZH2WS00 Mfr#: 86051-05
You're Surrounded
The Plantronics GameCom 780 USB headset with Dolby technologies transforms standard audio into a stunning 7.1 surround sound experience. The noise-canceling mic kills background noise so your commands are loud and clear. When you need to take a break, built-in spin joints let the earpods lay flat for easy storage. Need to adjust volume? No problem. The controls are right on the earpods so you'll always have eyes on. The GameCom 780 is built to last with superhero-strength cords and joints; ultra-comfortable ear cushions and headband let you stay in the game for as long as it takes.
Poly - Plantronics GameCom 780 - headset
Headset - 7.1 channel - wired
Recommended Use
Computer
Headphones Form Factor
Full size binaural
Wired
Sound Output Mode
Surround Sound
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Controls
Mute, volume
Microsoft Certification
Compatible with Windows 7
Recommended Use
Computer
Audio Output
Full size binaural
Wired
Sound Output Mode
Surround Sound
Built-in Decoders
Dolby Pro Logic II
Frequency Response
20 - 20000 Hz
Diaphragm
40 mm
In-Cord Volume Control
Microphone
Boom
Frequency Response
100 - 8000 Hz
Remote Control
Controls
Mute, volume
Connector Type
USB (4 PIN USB Type A)
Cable Details
Headset cable - 2 m
