You're Surrounded
The Plantronics GameCom 780 USB headset with Dolby technologies transforms standard audio into a stunning 7.1 surround sound experience. The noise-canceling mic kills background noise so your commands are loud and clear. When you need to take a break, built-in spin joints let the earpods lay flat for easy storage. Need to adjust volume? No problem. The controls are right on the earpods so you'll always have eyes on. The GameCom 780 is built to last with superhero-strength cords and joints; ultra-comfortable ear cushions and headband let you stay in the game for as long as it takes.
- Poly - Plantronics GameCom 780 - headset
- Product Type
- Headset - 7.1 channel - wired
- Recommended Use
- Computer
- Headphones Form Factor
- Full size binaural
- Connectivity Technology
- Wired
- Sound Output Mode
- Surround Sound
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Boom
- Controls
- Mute, volume
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Product Type
- Recommended Use
- Computer
Audio Output
- Wired
- Sound Output Mode
- Surround Sound
- Built-in Decoders
- Dolby Pro Logic II
- 20 - 20000 Hz
- Diaphragm
- 40 mm
- In-Cord Volume Control
Microphone
- Boom
- 100 - 8000 Hz
Remote Control
- Controls
- Mute, volume
- Connector Type
- USB (4 PIN USB Type A)
- Cable Details
- Headset cable - 2 m
- Limited warranty - 2 years
