The stylish CS60 wireless headset system gives excellent sound quality and hands free wireless freedom up to 100m from your desk (typical office up to 50m). The lightweight and stylish headset can be converted into 3 styles: over the ear, headband and Plantronics' unique behind the neck design. CS60 has a talk time of up to 9 hours and you can even take calls when you are away from your desk using Plantronics' optional handset lifter. The IntelliStand feature senses when the headset has been removed from the base automatically lifting the handset and directing your call into the headset.
- Poly CS 60 - headset - with Electronic Hook Switch APS-1
- Product Type
- Headset - DECT - wireless
- Recommended Use
- Phone
- Headphones Form Factor
- Convertible - monaural
- Connectivity Technology
- Wireless
- Wireless Technology
- DECT
- Headphones Technology
- Dynamic
- Radio Frequency Range
- 1.8GHz
- Sound Output Mode
- Mono
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- Controls
- Mute, volume
- 2-year warranty
- Bundled with
- Electronic Hook Switch APS-1
- Product Type
- 27.5 g
- Recommended Use
- Phone
- Max Operating Distance
- 100 m
- Bundled with
Audio Output
- Dynamic
- Wireless
- DECT
- Sound Output Mode
- Mono
Microphone
- Boom
- Mono
Remote Control
- Controls
- Mute, volume
Wireless Link
- 1.8GHz
- Transmission Range
- 100 m
- Included Accessories
- Headband, base station, earloop
- Battery
- Headset battery rechargeable - Lithium Ion
- Run Time (Up To)
- 9 hour(s)
- Standby Time
- 60 hours
- Limited warranty - 2 years
