More headset for your UC dollar. Enter UC with the best-featured headset you never thought your budget could afford. Blackwire 300 series USB headsets are a simple-to-use, comfortable, and durable choice for conference calls, web-based training, and PC multimedia applications. Plus, they're priced right, easy to deploy, and offer a simple-to-upgrade UC solution that IT can roll out easily and rely on.
- Poly Blackwire C320-M - headset
- Product Type
- Headset - wired
- Recommended Use
- Computer
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Boom
- Controls
- Mute, volume, answer/end
- 2-year warranty
- Product Type
- Headset - wired
- Series
- 300 Series
- Recommended Use
- Computer
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- In-Cord Volume Control
Microphone
- Boom
- 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- USB (4 PIN USB Type A)
- Cable Details
- Headset cable
- Limited warranty - 2 years
