Poly Plantronics Blackwire C310-M (MS Lync) USB UC Headset - Mono (was 84Y9)
Quicklinx: DD6XWS00 Mfr#: 85618-101
Enter UC with the best-featured headset you never thought your budget could afford. Blackwire 300 series USB headsets are a simple-to-use, comfortable, and durable choice for conference calls, web-based training, and PC multimedia applications. Inline controls make it simple to answer and end PC calls and control volume and mute. The lightweight metal headband provides durability while delivering a comfortable and secure fit, while the unique Dynamic EQ feature optimizes sound quality and adjusts settings on the fly, creating outstanding sound for voice, music, and multimedia. The Blackwire 300 series is ideal for those new to PC telephony as well as organizations looking for a UC solution that's easy to roll out, manage, and upgrade.
Poly Blackwire C310-M - headset
Headset - wired
Recommended Use
Computer - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Mono
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Controls
Mute, volume, answer/end
Headset - wired
Series
300 Series
Recommended Use
Audio Output
On-ear
Wired
Sound Output Mode
Mono
Frequency Response
20 - 20000 Hz
In-Cord Volume Control
Microphone
Boom
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A)
Cable Details
Headset cable
