Let your team focus on collaboration rather than connecting peripherals. With a versatile 3.5 mm cable, Blackwire 215 can work with laptops, smartphones and tablets. Plus, the controls are so intuitive that anyone can use them.
The durable headset stands up to wear and tear. It easily folds flat to make storage easy at the end of the day. And all of this comes at an accessible price point, so you can equip your team for success.
Plantronics renowned audio technology is built into every Blackwire 215 headset. The noise-canceling microphone reduces background noise, so your team will always sound clear and confident.
Versatile and intuitive
Let your team focus on collaboration rather than connecting peripherals. With a versatile 3.5 mm cable, Blackwire 215 can work with laptops, smartphones and tablets. Plus, the controls are so intuitive that anyone can use them. -
Durability meets affordability
The durable headset stands up to wear and tear. It easily folds flat to make storage easy at the end of the day. And all of this comes at an accessible price point, so you can equip your team for success. -
Exceptional sound
- Poly Blackwire C215 - headset
- Product Type
- Headset - wired
- Recommended Use
- Phone, computer
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Mono
- Microphone
- Boom
- Controls
- Mute, volume, answer/end
- Product Type
- Headset - wired
- Headband Material
- Metal
- Recommended Use
- Phone, computer
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Mono
- In-Cord Volume Control
Microphone
- Boom
Remote Control
- Controls
- Connector Type
- Headset (mini-phone stereo 3.5 mm 4-pole)
- Cable Details
- Headset cable
