Poly Plantronics AL10 Inline Limiter
Quicklinx: 8526WS00 Mfr#: 86580-01
Simply add the AL10 in-line limiter with your Plantronics professional headset. Helps businesses comply with the EU Noise@Work legislation by keeping
headset daily noise exposure level below the 85 dBA legislative limit.
  • Noise at work compliance
    Helps businesses comply with EN 2003/10/EC European directive by keeping headset daily noise exposure level below the 85 dBA legislative limit.
  • Universal fit
    For simplicity of installation, AL10 can be installed in any orientation either to the headset or bottom cable QD connectors.
  • No additional power requirements
    The AL10 only requires a tiny amount of power and uses the AC power which is surplus in the telephone receive line without having any noticeable effect on speech quality.
  • Security
    Included QD lock to permanently attach the AL10 in-line with your Plantronics professional corded headset. The AL10 fits in between the headset and bottom cable using the Quick Disconnect. The QD lock prevents the user from accidentally removing the AL10 from the bottom cable.
Poly AL10 Smart Limiter - noise level limiter for headset
Noise level limiter
Intended For
Headset
EncorePro; Entera; SupraPlus; Entera USB
Noise level limiter
Intended For
Headset
Poly EncorePro , Poly Entera , Poly SupraPlus , Poly - Plantronics Entera USB
