The receiver of unlimited possibilities – in image, sound and programming diversity
The fact that the VSX-1131 has seven amplifier channels immediately points to the major difference to the smaller models. With the VSX-1131 the serious home cineaste can also operate a Dolby Atmos loudspeaker set with its additional ceiling speakers or "Atmos Enabled Speakers" and so get the first truly enveloping sound in all three spatial dimensions. dts:X as a second object-based surround format follows in a free firmware upgrade. With 160 watts per channel, the amplifier output meets higher demands, similar to the seven HDMI ports, one of which is located on the front panel. This allows you to quickly connect external players without much hassle. The VSX-1131 supports 4K UltraHD with HDR on every HDMI port, while it can convert Full HD into 4K using its powerful video scalers.
Music lovers actually no longer need to connect a player to the VSX-1131, because the receiver already has all the various streaming options installed. With Spotify, Tidal and Deezer, all the payment streaming services are supported; with the latter two even providing full CD quality. TuneIn adds thousands of web radio stations, while AirPlay, Google Play and Bluetooth provide matching wireless access to every tablet or smart phone. And if you’re planning a multi-room system in the near future, you’ll be happy to know that the VSX-1131 is already compatible with FireConnect and so able to feed all connected sources into a corresponding system.
(*) Deezer, Tidal, Google Cast, FireConnect and dts:X are available after free firmware update in the summer of 2016. For the latest information on firmware updates, please visit our website or follow us on the social networks.
Advanced DAC
It incorporates a high-grade 384 kHz / 32-bit DAC produced by AMK which offers clear, delicate audio reproduction thanks to a unique digital filter which achieves extremely low distortion. -
Create the ideal acoustic environment for surround sound with MCACC
Pioneer's MCACC (Multi-Channel Acoustic Calibration System), developed with the expertise of professional recording studios creates the ideal acoustic environment. -
Phase Control
As an ultimate solution for phase lag between the subwoofer and main L+R speakers, Phase Control compensates the delayed bass to improve sound synchronization. Consequently, it makes LFE more dynamic and achieves clear reproduction of sound in the mid and high-frequency bands. -
Dolby Atmos and DTS:X support
The advanced object-based audio formats, Dolby Atmos and DTS:X are both supported. Dolby Atmos technology utilizes object-based data as opposed to traditional channel-based data and creates a three dimensional soundscape in the room utilizing height-based audio information in addition to the traditional horizontal-based audio that is offered by channel based solutions. -
Ultra HD 4K and HDR compatibility
VSX-1131 supports 4K / 60p / 4:4:4 24-bit video signal transmission with HDCP 2.2 technology, ensuring compatibility with many Ultra HD 4K sources and televisions. In addition, VSX-1131 is also ready for the HDR (High Dynamic Range) and BT.2020 video standards. -
Internet radio and online music
Enjoy a limitless flow of music, sports, talk, and news entertainment from Internet radio stations and online music services. -
Built-in dual-band Wi-Fi and Bluetooth wireless technologies
High-fidelity, high-resolution sound sources can be enjoyed wirelessly through a Wi-Fi connection that supports dual band 5 GHz (11a/n) and 2.4 GHz (11b/g/n) offering faster transmission with fewer interruptions. Music can also be streamed simply and easily via the integration of wireless Bluetooth. -
Uncompressed HD audio
VSX-1131 supports various high-definition audio formats including Dolby TrueHD and DTS-HD.
- Pioneer VSX-1131 - AV network receiver - 7.2 channel
- Product Type
- Enclosure Colour
- Black
- Audio Channels
- Surround Sound
- Decoders
- Dolby Surround, DTS-ES decoder, DTS 96/24, Dolby Digital, DTS decoder, DTS Express, Dolby Digital Plus, SBC decoder, DSD decoder, Dolby TrueHD, DTS-HD Master Audio, DTS-HD High Resolution, Dolby Atmos
- Surround Sound Effects
- Front Stage Surround Advance
- Surround System Class
- 7.2 channel
- Source
- Network, USB-host, Bluetooth
- Audio Formats
- WAV, AAC, AIFF, MP3, FLAC, DSD, ALAC
- Radio System
- AM/FM - 40 preset stations
- Streaming Services
- Spotify, TuneIn
- Ethernet, Fast Ethernet, Wi-Fi, Bluetooth
- Display
- Fluorescent display
- 43.5 cm x 37.05 cm x 17.3 cm
- 10 kg
- Product Type
- Enclosure Colour
- Black
Audio System
- Audio Channels
- Surround Sound
- Decoders
- 3D Technology
- Functions
- Digital player, AV network receiver, internet radio
- Source
- Audio Formats
- Audio D/A Converter
- 32bit / 384kHz
- Digital Sound Processor (DSP)
- 3D Pass-Through
- 7.2 channel
- Amplifier Output details
- 160 watt - 6 ohm - at 1 kHz - THD 1.0% - 1 channels
- Built-in clock
- Sleep timer
- Auto power off, Bi-Amplifying, upgradeable firmware, Advanced Sound Retriever (ASR) technology, dual-zone capability, Bluetooth Audio Streaming, Audio Return Channel (ARC), auto level control (ALC), Apple AirPlay support, iPod/iPhone/iPad ready, smartphone remote controlled, x.v.Color, Deep Colour, Multi-Channel Acoustic Calibration Circuit Pro (MCACC Pro), Google Cast support, High-Resolution Audio
Signal Processing Features
- HDMI Pass-Through
- Up to 4K
- Upscaling via HDMI
- Up to 4K
Radio System
- AM/FM - digital radio tuner
- Preset Station Qty
Network & Internet Multimedia
- Spotify, TuneIn
Display
- Display Type
- Connectors
- Audio line-in (mini-phone stereo 3.5 mm) - front , Headphones (phone stereo 6.3 mm) - front , USB (4 PIN USB Type A) - front , HDMI input (19 pin HDMI Type A) - front , 6 x HDMI input (19 pin HDMI Type A) - rear , 2 x HDMI output (19 pin HDMI Type A) - rear , LAN (RJ-45) - rear , 2 x digital audio input (optical) (TOS Link) - rear , Digital audio input (coaxial) (RCA) - rear , 2 x composite video input (RCA) - rear , Component video input (RCA x 3) - rear , 4 x audio line-in (RCA x 2) - rear , 2 x subwoofer output (RCA) - rear , 9 x speakers output (banana/spade x 2) - rear , Phono input (RCA x 2) - rear , Audio line-out (multi zone) (RCA x 2) - rear
- Included Accessories
- Auto calibration microphone, universal remote control
- 570 watt
- Power Consumption Stand by
- 0.15 watt
- 43.5 cm
- 37.05 cm
- 17.3 cm
- 10 kg
