Pioneer PLX-500-W Turntable Direct Drive White
Quicklinx: J4SSWS00 Mfr#: PLX-500-W
£290.84 ex VAT
£349.00 inc VAT
Marketing description is not available.
Pioneer PLX-500 - turntable
Turntable
Enclosure Colour
White
Audio Channels
Stereo
Audio Specifications
Turntable 50 dB
Turntable
Direct drive - 78rpm, 33.3rpm, 45rpm
45 cm x 36.8 cm x 15.9 cm
10.7 kg
Turntable
Enclosure Colour
White
Audio System
Audio Channels
Stereo
Functions
Turntable
Turntable SNR - 50 dB
Turntable
Speeds Supported
Drive Type
Direct drive
Effective Arm Length
23.05 cm
Platter
Aluminium diecast 33.2 cm
Wow & Flutter
0.15 % (WRMS)
Pitch control, hinged detachable dust cover, built-in USB audio adapter
Connectors
Audio line-out (RCA x 2) - rear , USB (4 PIN USB Type B) - rear
Audio cable, USB cable, 45rpm vinyl adapter
45 cm
36.8 cm
15.9 cm
10.7 kg
Brand: Pioneer
