Pioneer PLX-500-K Turntable Direct Drive - Black
Quicklinx: J4SRWS00 Mfr#: PLX-500-K
Hurry, only 2 left in stock!
£290.84 ex VAT
£349.00 inc VAT
The PLX-500 inherits the layout of the PLX-1000 professional turntable and produces a warm, clear analog sound. The perfect deck if you want to start playing with vinyl or if you just want to listen to your record collection at home.
  • Excellent sound design
    Just like the PLX-1000, the PLX-500 is built to produce a high-quality vinyl sound. Short audio routing from the stylus to the outputs reduces distortion, while the phono/line output switch lets you connect directly to your sound system or to powered speakers with no need for an external amplifier.
  • Easy digital recording
    Record your vinyl collection to high-quality digital files by simply connecting the turntable to your PC or Mac via the USB out.
  • Smooth DJ play
    Use the PLX-500 to mix and scratch your vinyl records or combine the turntable with rekordbox dvs, to play and perform with your digital files.
  • Cover art display
    Put your record covers on display while listening to your vinyl thanks to the sleeve stand inside the dust cover.
  • Start from scratch
    This turntable comes with all the accessories you need to get started: a dust cover with jacket stand, a slipmat and a silver edition PC-HS01-S headshell.
Pioneer DJ PLX-500 - turntable
Turntable
Enclosure Colour
Audio Channels
Stereo
Audio Specifications
Turntable 50 dB
Turntable
Direct drive - 78 rpm, 33.3 rpm, 45 rpm
110-220 V (50/60 Hz)
45 cm x 36.8 cm x 15.9 cm
10.7 kg
1-year warranty
Turntable
Enclosure Colour
Audio System
Audio Channels
Stereo
Functions
Turntable
Turntable SNR - 50 dB
Turntable
Speeds Supported
Drive Type
Direct drive
Effective Arm Length
23.05 cm
Platter
Aluminium diecast 33.2 cm
Wow & Flutter
0.15 % (WRMS)
Pitch control, hinged detachable dust cover, built-in USB audio adapter
Connectors
Audio line-out (RCA x 2) - rear , USB (4 PIN USB Type B) - rear
Audio cable, USB cable, 45rpm vinyl adapter
Limited warranty - 1 year
45 cm
36.8 cm
15.9 cm
10.7 kg
Brand: Pioneer
