The PLX-500 inherits the layout of the PLX-1000 professional turntable and produces a warm, clear analog sound. The perfect deck if you want to start playing with vinyl or if you just want to listen to your record collection at home.
Excellent sound design
Just like the PLX-1000, the PLX-500 is built to produce a high-quality vinyl sound. Short audio routing from the stylus to the outputs reduces distortion, while the phono/line output switch lets you connect directly to your sound system or to powered speakers with no need for an external amplifier. -
Easy digital recording
Record your vinyl collection to high-quality digital files by simply connecting the turntable to your PC or Mac via the USB out. -
Smooth DJ play
Use the PLX-500 to mix and scratch your vinyl records or combine the turntable with rekordbox dvs, to play and perform with your digital files. -
Cover art display
Put your record covers on display while listening to your vinyl thanks to the sleeve stand inside the dust cover. -
Start from scratch
This turntable comes with all the accessories you need to get started: a dust cover with jacket stand, a slipmat and a silver edition PC-HS01-S headshell.
 - Pioneer DJ PLX-500 - turntable
- Product Type
 - Turntable
- Enclosure Colour
 - Black
- Audio Channels
 - Stereo
- Audio Specifications
 - Turntable 50 dB
- Turntable
 - Direct drive - 78 rpm, 33.3 rpm, 45 rpm
- Power
 - 110-220 V (50/60 Hz)
 - 45 cm x 36.8 cm x 15.9 cm
 - 10.7 kg
 - 1-year warranty
- Product Type
 - Turntable
- Enclosure Colour
 - Black
Audio System
- Audio Channels
 - Stereo
- Functions
 - Turntable
 - Turntable SNR - 50 dB
Turntable
- Speeds Supported
- Drive Type
 - Direct drive
- Effective Arm Length
 - 23.05 cm
- Platter
 - Aluminium diecast 33.2 cm
- Wow & Flutter
 - 0.15 % (WRMS)
 - Pitch control, hinged detachable dust cover, built-in USB audio adapter
- Connectors
 - Audio line-out (RCA x 2) - rear , USB (4 PIN USB Type B) - rear
- Included Accessories
 - Audio cable, USB cable, 45rpm vinyl adapter
- Voltage Required
 - Limited warranty - 1 year
 - 45 cm
 - 36.8 cm
 - 15.9 cm
 - 10.7 kg
