Pioneer HDJ-CUE1BT Bluetooth Headphones
Quicklinx: J4SVWS00 Mfr#: HDJ-CUE1BT-K
Connectivity: Wireless
Hurry, only 3 left in stock!
£74.17 ex VAT
£89.00 inc VAT
Start your DJ journey with HDJ-CUE1BT headphones.
While these entry-level cans are very affordable, they match many of the features and quality benchmarks set by the professional headphones range. Choose the HDJ-CUE1BT for a pro look and feel, rich sound, compact and flexible design, and high-quality finish. Enjoy specialist sound tuning, perfectly hear low frequencies in the bass and kick drums so you can mix precisely and know exactly what your friends will hear when you drop the next track.
Match your individual style and listen to music on the move thanks to the built-in Bluetooth technology.
  • High-quality sound
    Hear the full richness of your music when DJing or just listening to a favorite track. Dynamic drivers enable you to feel the bass and hear mids and high-end sounds with crystal clarity, helping you to mix with pin-point precision.
  • Built to last
    Each HDJ-CUE1BT model can handle the heavy stress that DJing places on headphones. All moving parts have passed strict in-house durability tests and extra-strong metal sliders in the headband bring added reliability.
  • Bluetooth wireless technology
    Bluetooth gives you the freedom to listen to music wirelessly. The built-in microphone enables you to take phone calls and, when you want to start DJing, you can simply connect the included cable to focus on your mix.
  • Comfortable pro-style design
    With ear cups that turn a full 90 degrees and a flexible, cushioned headband, you can comfortably monitor your mix your way. Listen with one ear while the other cup rests on the back of your head, or while your headphones are draped around your neck.
  • Compact and portable
    The lightweight, folding design means you can easily take your headphones wherever you go.
  • Detachable cable
    A detachable coiled cable is included, giving you freedom to move while performing, and its bayonet connector prevents accidental disconnections.
Pioneer DJ HDJ-CUE1BT - headphones with mic - 3.5 mm jack
Headphones - Bluetooth - wireless - 3.5 mm jack
Style
DJ
Matte black
Headphones Form Factor
Full size
Foldable
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 5 - 30000 Hz
Impedance
32 Ohm
Max Input Power
2000 mW
Microphone Technology
Condenser
Microphone Operation Mode
Omni-directional
1-year warranty
Style
DJ
250 g
Matte black
Max Operating Distance
10 m
Audio Output
Full size
Headphones Cup Type
Closed
Foldable
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Audio Codec
SBC, AAC
Bluetooth Version
Bluetooth 5.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Frequency Response
5 - 30000 Hz
Max Input Power
2000 mW
Impedance
32 Ohm
Max Sound Pressure
104 dB
Diaphragm
40 mm
Adjustable Headband
Microphone
Built-in
Condenser
Omni-directional
Frequency Response
100 - 4000 Hz
Connector Type
Headphones (mini-phone stereo 3.5 mm 4-pole)
Cable
Detachable Cable
Cable Length
1.2 m
Cable Details
Headphones cable - detachable - coiled - 1.2 m , USB charge cable - 50 cm
Headphone battery rechargeable - lithium polymer
Run Time (Up To)
30 hour(s)
Recharge Time
2.5 hour(s)
1-year warranty
Brand: Pioneer
