Start your DJ journey with HDJ-CUE1BT headphones.
While these entry-level cans are very affordable, they match many of the features and quality benchmarks set by the professional headphones range. Choose the HDJ-CUE1BT for a pro look and feel, rich sound, compact and flexible design, and high-quality finish. Enjoy specialist sound tuning, perfectly hear low frequencies in the bass and kick drums so you can mix precisely and know exactly what your friends will hear when you drop the next track.
Match your individual style and listen to music on the move thanks to the built-in Bluetooth technology.
High-quality sound
Hear the full richness of your music when DJing or just listening to a favorite track. Dynamic drivers enable you to feel the bass and hear mids and high-end sounds with crystal clarity, helping you to mix with pin-point precision. -
Built to last
Each HDJ-CUE1BT model can handle the heavy stress that DJing places on headphones. All moving parts have passed strict in-house durability tests and extra-strong metal sliders in the headband bring added reliability. -
Bluetooth wireless technology
Bluetooth gives you the freedom to listen to music wirelessly. The built-in microphone enables you to take phone calls and, when you want to start DJing, you can simply connect the included cable to focus on your mix. -
Comfortable pro-style design
With ear cups that turn a full 90 degrees and a flexible, cushioned headband, you can comfortably monitor your mix your way. Listen with one ear while the other cup rests on the back of your head, or while your headphones are draped around your neck. -
Compact and portable
The lightweight, folding design means you can easily take your headphones wherever you go. -
Detachable cable
A detachable coiled cable is included, giving you freedom to move while performing, and its bayonet connector prevents accidental disconnections.
- Pioneer DJ HDJ-CUE1BT - headphones with mic - 3.5 mm jack
- Product Type
- Headphones - Bluetooth - wireless - 3.5 mm jack
- Style
- DJ
- Matte black
- Headphones Form Factor
- Full size
- Foldable
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 5 - 30000 Hz
- Impedance
- 32 Ohm
- Max Input Power
- 2000 mW
- Microphone Technology
- Condenser
- Microphone Operation Mode
- Omni-directional
- 1-year warranty
- Product Type
- Style
- DJ
- 250 g
- Matte black
- Max Operating Distance
- 10 m
Audio Output
- Full size
- Headphones Cup Type
- Closed
- Foldable
- Dynamic
- Wireless
- Bluetooth
- Bluetooth Audio Codec
- SBC, AAC
- Bluetooth Version
- Bluetooth 5.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- 5 - 30000 Hz
- Max Input Power
- 2000 mW
- Impedance
- 32 Ohm
- Max Sound Pressure
- 104 dB
- Diaphragm
- 40 mm
- Adjustable Headband
Microphone
- Form Factor
- Built-in
- Condenser
- Omni-directional
- 100 - 4000 Hz
- Connector Type
- Headphones (mini-phone stereo 3.5 mm 4-pole)
Cable
- Detachable Cable
- Cable Length
- 1.2 m
- Cable Details
- Headphones cable - detachable - coiled - 1.2 m , USB charge cable - 50 cm
- Battery
- Headphone battery rechargeable - lithium polymer
- Run Time (Up To)
- 30 hour(s)
- Recharge Time
- 2.5 hour(s)
- 1-year warranty
Pioneer HDJ-CUE1BT Bluetooth Headphones
