Pioneer HDJ-CUE1 Headphones
Quicklinx: J4STWS00 Mfr#: HDJ-CUE1
Connectivity: Wired
£40.84 ex VAT
£49.00 inc VAT
Start your DJ journey with HDJ-CUE1 headphones.
While these entry-level cans are very affordable, they match many of the features and quality benchmarks set by the professional headphones range. Choose the HDJ-CUE1 for a pro look and feel, rich sound, compact and flexible design, and high-quality finish. Enjoy specialist sound tuning, perfectly hear low frequencies in the bass and kick drums so you can mix precisely and know exactly what your friends will hear when you drop the next track.
  • High-quality sound
    Hear the full richness of your music when DJing or just listening to a favorite track. Dynamic drivers enable you to feel the bass and hear mids and high-end sounds with crystal clarity, helping you to mix with pin-point precision.
  • Built to last
    Each HDJ-CUE1 model can handle the heavy stress that DJing places on headphones. All moving parts have passed strict in-house durability tests and extra-strong metal sliders in the headband bring added reliability.
  • Comfortable pro-style design
    With ear cups that turn a full 90 degrees and a flexible, cushioned headband, you can comfortably monitor your mix your way. Listen with one ear while the other cup rests on the back of your head, or while your headphones are draped around your neck.
  • Compact and portable
    The lightweight, folding design means you can easily take your headphones wherever you go.
  • Detachable cable
    A detachable coiled cable is included, giving you freedom to move while performing, and its bayonet connector prevents accidental disconnections.
Pioneer DJ HDJ-CUE1 - headphones - 3.5 mm jack
Headphones - wired - 3.5 mm jack
Style
DJ
Headphones Form Factor
Full size
Foldable
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 5 - 30000 Hz
Impedance
32 Ohm
Max Input Power
2000 mW
1-year warranty
Style
DJ
215 g
Audio Output
Full size
Headphones Cup Type
Closed
Foldable
Dynamic
Wired
Sound Output Mode
Stereo
Frequency Response
5 - 30000 Hz
Max Input Power
2000 mW
Impedance
32 Ohm
Max Sound Pressure
104 dB
Diaphragm
40 mm
Adjustable Headband
Connector Type
Headphones (mini-phone stereo 3.5 mm)
Cable
Detachable Cable
Cable Length
1.2 m
Cable Details
Headphones cable - detachable - coiled - 1.2 m
1-year warranty
Connectivity: Wired
Brand: Pioneer
