Pioneer DM-40D Speakers Black
Quicklinx: J4SNWS00 Mfr#: DM-40D
£124.17 ex VAT
£149.00 inc VAT
The DM series speakers deliver balanced, punchy bass sound and they can pump out extra power thanks to the Class D amplifier and 4-inch woofer in each unit. Flick the switch to change from DJ mode to Production mode and the DSP settings will automatically create a top sound for each application.
  • Advanced design for higher quality sound
    Each DM series speaker produces pure, balanced bass sound thanks to a Class D amplifier with 96 kHz sampling DSP. Another advancement from the DM-40 model comes in the updated design of the DECO convex diffusers which help deliver crystal-clear high frequencies in every direction, so you can enjoy a wide sweet spot and 3D stereo sound wherever you are in the room. The woofer and tweeter are perfectly aligned so you'll hear all sound frequencies clearly. The grooves on the ducts reduce air friction so bass is tight and punchy, even if you position the speakers against a wall. Plus, the curved front edges provide maximum rigidity and minimum resonance for clean audio at any volume level. The 4-inch woofer creates powerful sound without distorting, even if you pump up the volume.
  • 2-way sound mode - optimized for DJing and music production
    There's no need to decide whether you want a set of monitors that are made for DJing or making music, because the DM series speakers are perfect for both. Just flip the switch to choose either DJ mode or Production mode and the DSP settings will be optimized for the task, leaving you free to concentrate on your mix.
  • Easy to use with different DJ or production equipment
    With RCA and mini jack terminals, you can connect different kinds of gear such as DJ controllers and mixers, or the laptop or soundcard you use. Connecting your headphones is simple via the socket on the front panel and the level knob is right in front of you too.
Pioneer DJ DM-40D - monitor speakers
Monitor speakers
System Components
2 speakers
Enclosure Design
Bass reflex
Speaker Type
2-way - active
Amplifier Output Power
2 x 19W - D
Amplifier
Integrated
AC 110-240 V (50/60 Hz)
292 mm x 223 mm x 227 mm
4.7 kg
1-year warranty
Monitor speakers
Enclosure Colour
Enclosure Design
Bass reflex
Enclosure Material
MDF
Speaker System
System Components
2 speakers
Speaker Type
2-way - active
Amplifier Input Impedance
10 kOhm
Amplifier
Integrated
Amplifier Class
D
2 x 19W
Transmission Range
10 m
Headphone Output Jack
Speaker System Details
Driver Details
Speaker: woofer driver - 4" - fibreglass , Speaker: tweeter driver - 0.75" - Soft Dome
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , Audio line-in (RCA x 2) , Headphones (mini-phone stereo 3.5 mm)
3.5 mm to RCAx2 cable
Power Source
Integrated power supply
25 Watt
292 mm
223 mm
227 mm
4.7 kg
Dimensions (WxDxH) / Weight Details
Left channel speaker: 14.6 cm x 22.3 cm x 22.7 cm / 2.5 kg , Right channel speaker: 14.6 cm x 21.2 cm x 22.7 cm / 2.2 kg
Limited warranty - 1 year
Brand: Pioneer
