Pioneer BDR-209DBK 16x SATA Internal BD/DVD/CD Burner Black Bare
Quicklinx: 94VSWS00 Mfr#: BDR-209DBK
  • BD-RE
BDR-209DBK: 16x Internal BD/DVD/CD Burner. SATA Interface. No software included.
  • Up to 16x writing speed on BD-R media!
  • Write up to 50 Gbytes on one BD-R DL disc
  • QuickPlay - Movies are ready faster
  • Backwards compatible with DVD and CD media
Looking for the fastest drive in the market but already have software? Then the BDR-209DBK is the drive for you. The BDR-209DBK drive is perfect for system builders, for those looking to upgrade to a fast Blu-ray burner, or for those who already have software.
The BDR-209DBK is an internal SATA drive. It can burn up to 16x on BD-R (25GB) media and up to 14x on BD-R dual layer (50GB) media, which is the fastest in the market! The drive is also backwards compatible, so it can read and write to most DVD and CD formats. Click on the "Specifications" tab to see all supported media formats, as well as the read and write speeds achievable.
Want to watch Blu-ray 3D titles? Well the BDR-209DBK drive is 3D capable. All you need is 3D playback software and a 3D display system and you're ready to go.
Running out of hard drive space? Afraid of losing your valuable files when your hard drive crashes? With Blu-ray BD-R dual layer (DL) discs, you can store the equivalent of 10 single layer DVDs. Now you can have a backup you can trust and with fewer discs.
The BDR-209DBK drive has features such as a QuickPlay which enables movies discs to be ready faster, a Noise Suppression design to minimize noise, an Anti-Dust design to increase durability, and Precision Writing Technology to minimize write errors. And of course being a Pioneer drive, the BDR-209DBK drive supports a wide range of blank media.
  • Faster burning: 16x Blu-ray burner! Pioneer can now achieve up to 16x writing on BD-R media and up to 14x on BD-R Dual Layer (DL) discs.
  • Watch 3D movies: The drive is 3D capable. All you need is 3D playback software and a 3D display system.
  • Play movies faster: The amount of time between inserting a movie disc, and that disc being ready has been reduced. For movies on DVD and Blu-ray Disc, the disc is ready faster when compared to the BDR-208DBK.
  • A quieter drive: The tray cushion and the top cover of the BDR-209DBK has been designed to reduce disc rotation noise.
  • Increased life expectancy: The sound barrier design that traps noise inside the drive also works to keep dust outside the drive. This makes the drive much more dust resistant and drive failure due to dust is practically nonexistent.
  • Wide blank media support: Pioneer strives to have best in class performance over a wide range of media - our drives achieve this for a large variety of BD and DVD media. Refer to the drive's media support list for all supported media and the write speed that can be achieved.
  • Top quality writing: Our chassis' design maximizes disc stability and write quality by reducing warping at high speed caused by disc vibration, especially on the outer areas of the disc.
  • Faster burning
    16x Blu-ray burner! Pioneer can achieve up to 16x writing on BD-R media and up to 14x on BD-R Dual Layer (DL) discs.
  • A quieter drive
    The chassis' design maximizes disc stability and write quality by reducing warping at high speed caused by disc vibration, especially on the outer areas of the disc.
Pioneer BDR-209DBK - BD-RE drive - Serial ATA - internal
BD-RE drive - internal
Serial ATA
14.8 cm x 18 cm x 4.23 cm
740 g
Optical Storage
BD-RE - 5.25" x 1/2H
Read Speed
40x (CD) / 16x (DVD) / 12x (BD)
Write Speed
40x (CD) / 16x (DVD±R) / 8x (DVD±R DL) / 16x (BD-R SL) / 14x (BD-R DL)
Buffer Underrun Protection
Buffer Underrun Technology
Media Load Type
Tray
Microsoft Certification
Compatible with Windows 7
Serial ATA
14.8 cm
18 cm
4.23 cm
740 g
Optical Storage
Read Speed
Write Speed
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL, BD-R, BD-R DL, BD-RE, BD-RE DL, BD-ROM, BD-ROM DL, BD-R LTH, DVD-ROM DL
Media Load Type
Tray
Buffer Size
4 MB
QuickPlay
1 x SATA 1.5Gb/s
Compatible Bay
Front accessible
RoHS, WEEE
Microsoft Windows 7, Microsoft Windows XP SP3, Windows 8
