Pico Genie P50 Pro LED Mini Projector
Quicklinx: 9MR8WS00 Mfr#: 15232
The Pico Genie P50 Pro LED mini projector is the new upgraded version of the world's smallest projector with 40 lumens of brightness, extensive connectivity, a 2 hour battery and many in-the-box accessories. It's Ideal for anyone wanting great portability and a massive screen from a smartphone, laptop or tablet. Its unique features are:
Upgraded Features on the P50 Pro
Louder Speakers (1.5 watts)
Now supports up to 2TB external hard drives
Tripod thread and tripod included
Power bank feature for charging your portable USB devices whilst connected (smartphones, tablets etc)
Extended 3.5 hour battery capacity
Improved operating buttons on the device
LED charging light level indicator
Other Main Features
Tiny size (75mm x 75mm x 22mm) & weighs 148g
Extensive connectivity (VGA, HDMI, USB, SD, AV composite inputs) & direct SD/USB playback / no connected device required
40 lumens of brightness on battery and mains power
Can be used with almost any Smartphone (including Android, Windows and iPhone with the right cable)
World's smallest LED projector with extensive features
Measures only 9 x 7.5 x 2.2 cm and weighs just 160g
Projects up to an impressive 70" image from most devices
Unrivalled connectivity means you can connect almost any device with HDMI or VGA or just playback directly with MicroSD or USB inputs.
Mirror almost all smartphone screens, including Android, Windows, iPhone, iPad, tablets, laptops and other HDMI devices (additional cables needed)
Package Contents
Pico Genie P50 Pro Projector
Power Adaptor (UK plug)
HDMI cable
AV Cable
VGA Cable
User Manual
Tripod
Pico Genie P50 Pro - DLP projector
DLP projector
Built-in Devices
Speaker
Brightness
40 lumens
Contrast Ratio
800:1
Resolution
VGA (640 x 480)
Native Aspect Ratio
4:3
Bulb type
LED
Bulb life cycle
Up to 20000 hour(s) - normal mode , Up to 30000 hours - economic mode
Video Input
(NTSC, PAL) - MPEG-4, AVI, MJPEG, H.264, MOV, RMVB, RM, MKV
Supported Memory Cards
microSD
Speakers
Speaker(s) - integrated
9 cm x 7.5 cm x 2.2 cm
150 g
DLP projector
Built-in Devices
Speaker
Projector
Brightness
40 lumens
Contrast Ratio
800:1
Resolution
VGA (640 x 480)
Native Aspect Ratio
4:3
Bulb type
LED
Bulb life cycle
JPEG photo playback, BMP photo playback, PNG photo playback
Lens
Focus Type
Manual
Video Input
TV System
NTSC, PAL
Video Interfaces
VGA, HDMI
microSD
Digital Video Format
Speakers
Integrated
Output Power / Channel
1.5 Watt
1 x HDMI , 1 x USB - 4 pin USB Type A , 1 x VGA input , 1 x audio line-out - mini-phone 3.5 mm
Tripod, power adapter
1 x HDMI cable , 1 x VGA cable , 1 x A/V cable
Power Source
AC / battery
Run Time (Up To)
3.5 hour(s)
9 cm
7.5 cm
2.2 cm
150 g
