What is pi-topCEED?
The pi-topCEED allows teachers to easily deploy Raspberry Pi in the
classroom. It's a modular desktop that is simple to setup and use, and comes
with all required software pre-loaded for a plug and play teaching solution.
Designed for all ages and abilities, pi-topCEED provides educators with
an invaluable resource for teaching programming, computing and electronics;
unleashing students' creativity and curiosity. **pi-top** Classroom's cloud
interface, lets teachers paperlessly create an assignment, track student's
progress, provide feedback and build new or edit existing worksheets that
address the UK Computing curriculum and wider STEAM subjects.
pi-top's mission is to change the face of STEAM education with hardware
and software that makes it possible for any teacher, regardless of their
computer literacy, to deliver fun and engaging lessons across STEAM
subjects, especially the computing curriculum for key stages 2-5.
A comprehensive solution for STEAM education
pi-topCEED's operating system, pi-top OS, features our unique pi-top
CODER software providing many hours of project plans, coding tools for all
levels from simple drag and drop block-based language to more complex
workshops all laid out in an easy to understand, step-by-step format. In
addition, all pi-top CEED's come pre-loaded with an interactive
educational game, CEEDuniverse.
pi-topCEED also allows students to explore electronics, code and play
gamified content that interacts with modules students can connect to expand
the pi-topCEED's functionality and connect with the ever increasing array
of available IoT devices including the BBC Micro:bit. Simply add any USB
mouse and keyboard and you are ready to go.
Features and Benefits
Available in bright green or dark grey (search CD36)
Optimised for Raspberry Pi 3
- Quad-core 1.2 GHz 64-/32-bit ARM Cortex-A53
- Memory: 1 GB RAM at 900 MHz
- Storage: SD Card 8GB as standard
Slim form factor for easy storage
Adjustable stand
Rubber anti-slip surface points
Add-on board compatible - modular magnetic rail
14" HD LCD screen
- 1366 x 768 resolution
- PWM screen brightness control (available from pi-top OS)
- 262 K colours
- Anti-glare screen
What is in the package?
- pi-top CEED desktop (with 14" HD screen)
- pi-top hub
- 18V power supply
- Internal cables
- 8 GB SD card preloaded with pi-top OS
Pre-loaded Software and OS
pi-top OS based on Raspbian (Jessie with Pixel)
pi-topOS provides users with a familiar and stylish interface, improving the
out-of-the-box experience. It also comes with a specifically designed
software suite to integrate with pi-top hardware.
pi-top DASHBOARD is an interface that simplifies the way you interact with
Raspberry Pi and lets you personalise your pi-top to your liking!
pi-top CODER is an interface that allows you to access a number of Raspberry
Pi resources and projects. It will teach you to code, track your progress,
and test your code in real time! It includes a customized code editor with
dynamically draggable views for text input, application output and learning
instructions in a single screen.
- Python IDE
- Scratch
- Minecraft Pi
- 3D Slash
- CEEDuniverse
- Full Libre Office Suite
- Sonic Pi
CEEDuniverse
CEEDuniverse is our gamified educational software pre-installed with every
copy of pi-top OS. It includes real-world computing problems integrated into
puzzle-based game play. The course will take the user from learning about
basic data types and variables to writing complicated functions in new, fun
and engaging ways.
Find out more about CEEDuniverse at
www.pi-top.com/ceeduniverse
Plug and play ready
Pre-assembled with all required software installed. You'll be able to take your knowledge to the next level as soon as you take it out of the box. -
Merging practicality and design
Designed with ergonomics in mind, pi-topCEED comes with back stand adjustable up to 180ยบ. -
Hardware expansion
pi-topCEED teaches you amazing creations that you add code to in order to bring to life. Use pi-top add-ons by simply sliding an add-on into the Modular-Rail, then use pi-topCODER to learn amazing lesson plans that integrate fun physical computing projects.
- pi-topCEED - DIY kit
- Category
- Desktop
- Package Content
- pi-topPCB Hub, power adapter, case with display, cables
- Parameters
- PWM screen brightness control, modular rail for add-ons, adjustable viewing angle up to 65°
- Display
- LCD display - 1366 x 768 pixels - 14 in
- Processor
- Broadcom BCM2837 1.2 GHz (Quad-Core) - 64-bit
- Memory
- microSDHC, microSD - RAM 1 GB
- Graphics Accelerator
- VideoCore IV
- Wireless Protocol
- 802.11b/g/n, Bluetooth 4.1 LE
- Wired Protocol
- 10/100 Ethernet
- Grey
- 33.1 cm x 3.175 cm x 33.1 cm
- Designed For
- Raspberry Pi 3 Model B
- Product Type
- DIY kit
- Category
- Desktop
- Package Content
- Parameters
- Software Provided
- CEED Universe, Minecraft Pi, Libre Office, Chromium
- Supported Software
- Python
- Display
- LCD display 14 in - 1366 x 768 pixels - 262K colour
- Broadcom BCM2837
- Clock Speed
- 1.2 GHz
- Number of Cores
- Quad-Core
- 64-bit Architecture
RAM
- Technology
- LPDDR2 SDRAM
- Installed Size
- 1 GB
Flash Memory
- Supported Flash Memory Cards
Graphics System
- VideoCore IV
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.1 LE
- Wireless Protocol
- Wired Protocol
- 10/100 Ethernet
Interface Provided
- Interface Provided
- LAN - RJ-45 , CSI - ZIF , 4 x USB 2.0 - Type A , GPIO - 40 pin IDC , DSI - ZIF , Composite video/audio line-out - 4-pole mini-jack , HDMI output - Type A
- Grey
- 33.1 cm
- 3.175 cm
- 33.1 cm
- Designed For
