The pi-top is a Raspberry Pi laptop you build yourself! It is the perfect product to affordably and interactively learn about software and hardware. pi-top is shipped with the revolutionary pi-topOS, including CEEDuniverse and features our unique pi-topCODER software providing hundreds of hours of project worksheet, coding tools for all levels from simple drag and drop block-based language to more complex workshops all laid out in an easy to understand, step-by-step format.
- Learn how to Code in a gamified environment
- Build circuits
- Create your own hardware (and run it by programming your own software)
- 3D print your own creations and make cool things!
- Screen
- 13.3" HD TFT LCD screen
- Anti-glare
- 1366 x 768 resolution
- eDP 1.2 interface
- 262K colours
- 3W power consumption
- pi-top Hub
- Power Management
- Battery Connection
- Screen Driver
- PCB Rail Circuitry
- Raspberry Pi 3 model B:
- 1.2GHz quad-core ARM Cortex-A53
- Bluetooth 4.1 Classic and Bluetooth LE (Low Energy)
- 2.4GHz 802.11n WiFi
- Cortex A7 CPU
- 1 GB LPDDR2 RAM (900MHz)
- Video CORE IV, 3D graphics core
- Raspbian + pi-topOS.
- Cables included:
- HDMI Cable
- Micro USB Cable
- GPIO Breakout Cable
- Power Control Cable
- Keyboard USB Cable
- Smart Battery:
- 43-watt-hour
- 10 hour run time
- Two-wire SMBus 2.0 Interface
- Advanced charge algorithms:
- JEITA recommended profiles with variable current
- Active cell balancing for extended lifetime
- Base/Chassis
- Injection moulded ABS
- Available in Grey or Green
- Keyboard: US/UK QWERTY, DE available end of April.
- Acrylic slice allows easy access to internal hardware - black laser etched surface easy to customise to school emblem or just for fun.
- Rubberised anti-slip surface contact points
- Product dimensions:
- 341mm x 209mm (WxD)
- Front thickness: 10mm
- Rear thickness: 47mm
- Peripherals
- 8GB Class 10 SD card preloaded with pi-topOS
- 18V, 3A brick-type power supply - available with AU, BR, CN, EU, IN, ZA , CH, UK and US AC cables
- Tool kit for assembly
Screen
- Anti-glare
- eDP 1.2 interface
- 262K colours
pi-top Hub
- Power Management
- Screen Driver
- Cortex A7 CPU
Cables included:
- HDMI Cable
- Micro USB Cable
Smart Battery:
- 43-watt-hour
- 10 hour run time
Base/Chassis
Product dimensions:
Peripherals
