Pi-top Grey pi-top 8GB SD Card
Quicklinx: CQCSWS00 Mfr#: PT01-GY-UK-UK-02
The pi-top is a Raspberry Pi laptop you build yourself! It is the perfect product to affordably and interactively learn about software and hardware. pi-top is shipped with the revolutionary pi-topOS, including CEEDuniverse and features our unique pi-topCODER software providing hundreds of hours of project worksheet, coding tools for all levels from simple drag and drop block-based language to more complex workshops all laid out in an easy to understand, step-by-step format.
  • Learn how to Code in a gamified environment
  • Build circuits
  • Create your own hardware (and run it by programming your own software)
  • 3D print your own creations and make cool things!
Screen
13.3" HD TFT LCD screen
Anti-glare
1366 x 768 resolution
eDP 1.2 interface
262K colours
3W power consumption
pi-top Hub
Power Management
Battery Connection
Screen Driver
PCB Rail Circuitry
Raspberry Pi 3 model B:
1.2GHz quad-core ARM Cortex-A53
Bluetooth 4.1 Classic and Bluetooth LE (Low Energy)
2.4GHz 802.11n WiFi
Cortex A7 CPU
1 GB LPDDR2 RAM (900MHz)
Video CORE IV, 3D graphics core
Raspbian + pi-topOS.
Cables included:
HDMI Cable
Micro USB Cable
GPIO Breakout Cable
Power Control Cable
Keyboard USB Cable
Smart Battery:
43-watt-hour
10 hour run time
Two-wire SMBus 2.0 Interface
Advanced charge algorithms:
JEITA recommended profiles with variable current
Active cell balancing for extended lifetime
Base/Chassis
Injection moulded ABS
Available in Grey or Green
Keyboard: US/UK QWERTY, DE available end of April.
Acrylic slice allows easy access to internal hardware - black laser etched surface easy to customise to school emblem or just for fun.
Rubberised anti-slip surface contact points
Product dimensions:
341mm x 209mm (WxD)
Front thickness: 10mm
Rear thickness: 47mm
Peripherals
8GB Class 10 SD card preloaded with pi-topOS
18V, 3A brick-type power supply - available with AU, BR, CN, EU, IN, ZA , CH, UK and US AC cables
Tool kit for assembly
Screen
Anti-glare
eDP 1.2 interface
262K colours
pi-top Hub
Power Management
Battery Connection
Screen Driver
PCB Rail Circuitry
2.4GHz 802.11n WiFi
Cortex A7 CPU
Cables included:
HDMI Cable
Micro USB Cable
GPIO Breakout Cable
Power Control Cable
Keyboard USB Cable
Smart Battery:
43-watt-hour
10 hour run time
Base/Chassis
Product dimensions:
341mm x 209mm (WxD)
Peripherals
