Philips X-Line 34" HDMI DisplayPort Monitor
Quicklinx: DCL3WS00 Mfr#: 349X7FJEW/00
Diagonal Size: 34in
Max Resolution: 3440 x 1440
Response Time: 4ms
Speakers: None
Interfaces: DisplayPort, HDMI
£408.32 ex VAT
£489.98 inc VAT
This Philips UltraWide 34" display will amaze you with its Crystal clear 3440 x 1440 images and brilliant colours. Its fascinating UltraWide display with height adjustability gives you a panoramic view of the world.
  • Built-in stereo speakers for multimedia
    A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • USB 3.0 enables fast data transfers and smart phone charging
    Super-Speed USB 3.0 deploys a 5.0 gbit/s transfer rate, which is about 10 times faster than the USB 2.0 standard, significantly reducing data transfer time and saving you time and money. With more bandwidth, super-speed transfer rates, better power management and superior overall performance, USB 3.0 sets the latest global standard allowing you to use large-capacity storage devices. Sync-N-Go technology ensures you don't have to wait for bandwidth to be freed up any more. Your investment in USB 2.0 devices is protected as it is backwards-compatible.
  • MultiView enables active dual connect and view at the same time
    With the ultra-high resolution Philips MultiView display you can now experience a world of connectivity in comfort whether at the office or at home. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and Notebook side-by-side simultaneously, making complex multi-tasking work a breeze. Watching live football feeds from your set-top box on the right-hand side, while browsing the Internet from your notebook on the left is now easy. You may want to keep an eye on the live news feed with audio in the small window, while working on your latest blog.
  • DisplayPort connection for maximum visuals
    DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates — making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
  • CrystalClear images with UltraWide QHD 3440 x 1440 pixels
    These latest Philips screens deliver CrystalClear, UltraWide Quad HD 3440 x 1440-pixel images. Utilising high-performance panels with a high-density pixel count and 178/178 wide viewing angles, these new displays will make your images and graphics come alive. The UltraWide 21:9 format enables more productivity with more room for side-by-side comparisons and more viewable spreadsheet columns. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions, or a financial wizard working on huge spreadsheets, Philips displays deliver CrystalClear images.
  • Curved display design for a more immersive experience
    Desktop monitors offer a personal user experience, which suits a curved design very well. The curved screen provides a pleasant yet subtle immersion effect, which focuses on you at the centre of your desk.
  • HDMI for quick digital connection
    Enjoy crisp colourful images and audio with simple one-cable connection. A HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. A HDMI cable enables high-quality smooth digital video (up to 4K/UHD resolution at 60 Hz) and audio all transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
  • Narrow border display for seamless appearance
    The new Philips displays feature ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setups like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display.
  • Effortlessly smooth gameplay with AMD FreeSync™ technology
    Gaming shouldn't be a choice between choppy gameplay or broken frames. With the new Philips monitor it doesn't have to be. Get fluid, artefact-free performance at virtually any frame rate with AMD FreeSync™ technology, smooth, quick refresh and ultra-fast response time.
  • Ultra Wide-Color wider range of colours for a vivid picture
    Ultra Wide-Color Technology delivers a wider spectrum of colours for a more brilliant picture. The Ultra Wide-Color wider "colour gamut" produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive with vivid colours from Ultra Wide-Color Technology.
  • Height-adjustable for better ergonomic comfort
    The height-adjustable Ergo Base is a 'people-friendly' Philips monitor base that not only tilts, but is also height adjustable, so that each user can adjust the monitor to their personal preference for maximum viewing comfort and efficiency.
  • 100 Hz refresh rates for ultra-smooth images
    For gaming and video performance, you demand display with lag-free, ultra-smooth images. This Philips display redraws the screen image up to 100 times per second, much faster than a standard display. A lower frame rate can make enemies appear to jump from spot to spot on the screen, making them difficult targets to hit. With a 100-Hz frame rate, you get those critical missing images on the screen, showing enemy movement in ultra-smooth motion so you can easily target them.
Philips Brilliance X-line 349X7FJEW - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class C
Energy Consumption per Year
114 kWh
Power Consumption (On mode)
78 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Aspect Ratio
21:9
Native Resolution
3440 x 1440 at 60 Hz
Pixel Pitch
0.232 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 50000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, tilt
White, glossy, silver chrome
81 cm x 29.2 cm x 44.4 cm
8.21 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, RCM, CU-EAC
Display Type
Energy Class
Class C
114 kWh
78 W
Diagonal Size
34"
Viewable Size
34"
Curved Screen
Yes (1800R)
AMD FreeSync
Built-in Devices
USB 3.0 hub
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.232 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
40 - 100 Hz
Horizontal Refresh Rate
58 - 148 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Picture in picture, picture by picture, Sync on Green, sRGB colour management, SmartImage, SmartImage Game, Flicker Free technology, Mercury free, FreeSync Technology, Wide Viewing Angle, 99.5% sRGB colour gamut
81 cm x 29.2 cm x 44.4 cm - with stand
8.21 kg
2 x HDMI , DisplayPort , Audio line-in/out , Headphones , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Height, tilt
Tilt Angle
-5/+20
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable , 1 x audio cable
MTBF
50,000 hour(s)
69.95 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
Dimensions & Weight Details
With stand - width: 81 cm - depth: 29.2 cm - height: 44.4 cm - weight: 8.21 kg , Without stand - width: 810 cm - depth: 9.8 cm - height: 36.9 cm - weight: 6.43 kg
ENERGY STAR Certified
20 - 80%
Philips X-Line 34 Bundle deal on Philips X-Line 34" HDMI DisplayPort Monitor
£507.49
Diagonal Size: 34in
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Brand: Philips
Price Range Ex VAT: 300 - 500
