Run your display network over a local (LAN) connection. CMND and Control allows you to perform vital functions like controlling inputs and monitoring display status. Whether you're in charge of one screen or 100.
The built-in camera and speakers make this small touchscreen a truly versatile smart solution. Use it for retail audience measurement, footfall analytics, and more. Harness the power of Android AI apps to show targeted content. Or simply use your display for video conferencing.
Place your Philips Professional Display almost anywhere. PoE+ allows power and data to be delivered to your display over a single Ethernet cable. You won't need a power socket, but a power adapter is also supplied should you wish to plug in.
CMND and control, operate, monitor, maintain
Run your display network over a local (LAN) connection. CMND and Control allows you to perform vital functions like controlling inputs and monitoring display status. Whether you're in charge of one screen or 100. -
Built-in camera and speakers
The built-in camera and speakers make this small touchscreen a truly versatile smart solution. Use it for retail audience measurement, footfall analytics, and more. Harness the power of Android AI apps to show targeted content. Or simply use your display for video conferencing. -
Easy installation with PoE+ technology
Place your Philips Professional Display almost anywhere. PoE+ allows power and data to be delivered to your display over a single Ethernet cable. You won't need a power socket, but a power adapter is also supplied should you wish to plug in. -
Internal memory, upload content for instant play
Save and play content without the need for a permanent external player. Your Philips professional display has an internal memory, which allows you to upload media into the display for instant playback. The internal memory also functions as a cache for online streaming. -
CMND and create, develop and launch your own content
Take control of your content with CMND and Create. A drag-and-drop interface makes it simple to publish your own content, whether it's a daily specials board or branded corporate information. Preloaded templates and integrated widgets ensure that your stills, text and video will be up and running in no time.
- Philips Signage Solutions 10BDL4151T 10.1" LED-backlit LCD display - HD - for digital signage / interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen (multi touch) / camera
- Diagonal Class
- 10.1"
- Commercial Use
- Yes - interactive digital signage
- Platform
- Android
- Resolution
- 1280 x 800
- Display Format
- 720p
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:10
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Storage Drive Capacity
- 8 GB
- Storage Capacity
- 8 GB
- Supported Memory Cards
- microSD
- USB
- Included Accessories
- Silicone foot
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 26.1 cm x 2.9 cm x 16.72 cm
- 710 g
- 3-year warranty
- Product Type
- Diagonal Class
- 10.1"
- Commercial Use
- Combined With
- Touchscreen (multi touch) / camera
- Platform
- Android
- Operating System
- Android OS 7.1
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 26.1 cm
- 2.9 cm
- 16.72 cm
- 710 g
Display
- Resolution
- 1280 x 800
- Display Format
- 720p
- 16:10
- LED backlight
- Image Contrast Ratio
- 500:1
- Brightness
- 300 cd/m²
- Viewing Angle
- 160 degrees
- Viewing Angle (Vertical)
- 160 degrees
- Touchpoints Qty
- 5
- Response Time
- 30 ms
- Display Menu Language
- Multilingual
- Backlight Life
- 50,000 hour(s)
- Operation Hours / Days
- 24 / 7
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 75 x 75 mm
- VESA Compatibility
Media Player
- Supported Video Formats
- MPEG-4, AVI, MKV, MOV, VOB, FLV, TS, DAT, WebM, MPG, 3GP
- Supported Audio Formats
- MP3, WMA, AAC, M4A, MP2
- Supported Pictures Formats
- BMP, JPG, GIF, PNG, JPEG
- microSD
- USB Port
- Configuration
- 8 GB
- 8 GB
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 4 Watt
- Speakers
- 2 x speaker - 2 Watt
- Connector Type
- HDMI output , USB , Audio line-out , Remote control
- Silicone foot
- Cables Included
- USB cable , HDMI cable
- FCC Class A certified, UL, CB, RoHS
- Power Device
- Power adapter
- 0.5 Watt
- Smart power, PoE support
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 20 - 80%
