This brilliant Android based pocket projector is the ultimate multimedia device. With 350 lumens, 720p HD resolution, Wi-Fi, Bluetooth audio and much more functions this PicoPix is a powerful companion.
Internal battery
The PicoPix comes with a compact built-in rechargeable battery for long-lasting power. Long hours of continuous movie, photo and music playback enjoyment can be achieved on a single charge. This makes the PicoPix your perfect pocket companion. -
SmartEngine
Your pictures and videos deserve the best quality when it comes to sharing them with those around you. This is why the PicoPix pocket projector uses high quality SmartEngine LED technology to project your pictures and videos in brillinat colors and breathtaking contrast. -
Wi-Fi to go online
Wi-Fi to go online and share web content & to connect wireless with other devices within a network or to set up an own network.
- Philips PicoPix PPX4935 - DLP projector - 802.11 b/g/n wireless / LAN
- DLP projector - 720p
- Built-in Devices
- Battery (2000 mAh)
- Brightness
- 350 lumens
- Contrast Ratio
- 100000:1
- Resolution
- 1280 x 720
- Native Aspect Ratio
- 16:9
- Bulb type
- RGB LED
- Video Input
- IEEE 802.11 b/g/n wireless / LAN - MPEG-1, MPEG-2, MPEG-4, AVI, MJPEG, DivX, XviD, AVCHD, 3GPP, H.264, H.263, MOV, FLV, VOB, DAT, MKV, HEVC, H.265
- Supported Memory Cards
- SD Memory Card, SDHC Memory Card
- Speakers
- Speaker(s) - integrated
- 11.5 cm x 11.5 cm x 3.2 cm
- 351 g
- Built-in Devices
- Networking
- 802.11b/g/n
Projector
- Brightness
- 350 lumens
- Contrast Ratio
- 100000:1
- Image Size
- 38 cm - 381 cm
- Projection Distance
- 0.5 m - 5 m
- Throw Ratio
- 1.47:1
- Resolution
- 1280 x 720
- 16:9
- Bulb type
- RGB LED
- Controls & Adjustments
- Keystone correction
- JPEG photo playback, MP3 playback, High-bandwidth Digital Content Protection System (HDCP), BMP photo playback, DOC files support, PPT files support, XLS files support, PDF files support, WAV playback, PNG photo playback, DOCX files support, PPTX files support, XLSX files support, WMA playback, TIFF photo playback, Bluetooth Audio Support
Lens
- Focus Type
- Manual
Video Input
- Video Interfaces
- HDMI
- Digital Video Format
Media Player
- Operating System
- Android OS 4.4
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 3 Watt
- Expansion Slots
- 1 x SDHC Memory Card
- 1 x audio line-out - mini-phone 3.5 mm , 1 x HDMI input - 19 pin mini HDMI Type C , 1 x USB , 1 x USB - Micro-USB Type B , 1 x network
- Included Accessories
- Carrying case, remote control
- Cables Included
- 1 x mini HDMI-HDMI cable
- Run Time (Up To)
- 2 hour(s)
- 11.5 cm
- 11.5 cm
- 3.2 cm
- 351 g
- 5 °C
- 35 °C
- 15 - 85%
- Sound Emission
- 28 dBA
