Philips PPX4350 Pocket Projector  50 Lumens With Build In TV Tuner
Quicklinx: CPV6WS00 Mfr#: PPX4350/WIFI/INT
With HDMI, USB and a micro SD slot it's easy to project videos and pictures. PPX 4350 wireless supports screen mirroring through a Wi-Fi dongle. With the Bluetooth audio function it can be connected to Bluetooth speakers.
Philips PicoPix PPX4350W - DLP projector - Miracast Wi-Fi Display - black / white
DLP projector
Black / white
Built-in Devices
Speaker, lithium-ion battery (1800 mAh)
Brightness
50 lumens
Contrast Ratio
1300:1
Resolution
640 x 360
Native Aspect Ratio
16:9
Bulb type
RGB LED
Bulb life cycle
Up to 30000 hour(s) - economic mode
Video Input
(NTSC, SECAM, PAL), Miracast Wi-Fi Display - MPEG-4, AVI, MJPEG, H.264, MOV, MKV
Supported Memory Cards
microSD, microSDHC, microSDXC
Storage Capacity
4 GB Flash
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
9.7 cm x 5.4 cm x 1.7 cm
129 g
1-year warranty
DLP projector
Built-in Devices
Bluetooth
Enclosure Colour
Black / white
Projector
Brightness
50 lumens
Contrast Ratio
1300:1
Image Size
25 cm - 152 cm
Projection Distance
0.48 m - 2.85 m
Throw Ratio
2.2:1
Resolution
640 x 360
Native Aspect Ratio
16:9
Bulb type
RGB LED
Bulb life cycle
MP3 playback, High-bandwidth Digital Content Protection System (HDCP), wall colour correction, MP4 playback, WAV playback, USB QuickLink, MHL compliance, Bluetooth Audio Support, rear projection, integrated media player, Wi-Fi screen mirroring
Lens
Focus Type
Manual
Video Input
TV System
NTSC, SECAM, PAL
Video Interfaces
HDMI
Video Modes
Digital Video Format
LAN and Wireless Image Transferring Protocols
Wi-Fi Display, Miracast
Media Player
Storage Capacity
4 GB Flash
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Expansion Slots
1 x microSDHC
1 x HDMI input - 19 pin mini HDMI Type C , 1 x USB - 4 pin USB Type A , 1 x headphones - mini-phone stereo 3.5 mm
USB wireless network adapter
1 x mini HDMI-HDMI cable
Power Source
Run Time (Up To)
2 hour(s)
Recharge Time
3 hour(s)
9.7 cm
5.4 cm
1.7 cm
129 g
Limited warranty - parts and labour - 1 year
5 °C
35 °C
15 - 85%
Sound Emission
28 dBA
