This small and light pocket projector can easily be connected to various gadgets, an SD card or a USB stick to access your digital data. The addition of an integrated media player and embedded office viewer makes this PicoPix independent.
Project HD videos and images up to 120" in size
Enjoy the biggest mobile screen you ever had and share your HD media content wherever you want. With your PicoPix you are carrying a personal cinema in your pocket. -
Internal battery for long playtime
The PicoPix comes with a compact built-in rechargeable battery for long-lasting power. Up long hours of continuous movie, photo and music playback enjoyment can be achieved on a single charge. This makes the PicoPix your perfect pocket companion. -
LED technology for brilliant colors and high contrast
Your pictures and videos deserve the best quality when it comes to sharing them with those around you. This is why the PicoPix pocket projector uses high quality LED technology to project your pictures and videos in brilliant colors and breathtaking contrast. -
Integrated office viewer and media player
The integrated MP4 media player supports all common video and audio formats. This makes the PicoPix pocket projector a standalone device. The office viewer also allows you to share all common office files and pdf files. -
Perfect pocket companion
With a slim design your PicoPix pocket projector becomes your lightweight companion for business and private use. -
Various connections for all common appliances
The PicoPix pocket projector is offering quite a number of connections for your appliances. USB, HDMI, VGA, component, composite, SD/SDHC slot and a 3.5 mm audio output are at your disposal for unlimited entertainment.
- Philips PicoPix PPX3414 - DLP projector
- DLP projector
- Built-in Devices
- Speaker
- Brightness
- 140 lumens
- Contrast Ratio
- 1000:1
- Resolution
- WVGA (854 x 480)
- Native Aspect Ratio
- 16:9
- Bulb type
- RGB LED array
- Bulb life cycle
- Up to 30000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (NTSC, SECAM, PAL) - MPEG-4, AVI, MJPEG, H.264, H.263, MOV, MKV
- Supported Memory Cards
- SD Memory Card, SDHC Memory Card, SDXC Memory Card
- Storage Capacity
- 4 GB Flash
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p, 720i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 10.5 cm x 10.5 cm x 3.15 cm
- 270 g
- DLP projector
- Built-in Devices
- Speaker
Projector
- Brightness
- 140 lumens
- Contrast Ratio
- 1000:1
- Image Size
- 30.48 cm - 305 cm
- Projection Distance
- 0.5 m - 5 m
- Resolution
- WVGA (854 x 480)
- 16:9
- Bulb type
- RGB LED array
- Bulb life cycle
- USB powered, JPEG photo playback, MP3 playback, High-bandwidth Digital Content Protection System (HDCP), BMP photo playback, Office Viewer, MP4 playback, DOC files support, PPT files support, XLS files support, PDF files support, PNG photo playback, PPTX files support, XLSX files support
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- HDMI, composite video
- Video Modes
- Digital Video Format
Media Player
- Storage Capacity
- 4 GB Flash
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 1 Watt
- Speakers
- 1 x mixed channel
- Expansion Slots
- 1 x SDXC Memory Card
- 1 x HDMI input - 19 pin mini HDMI Type C , 1 x composite video/audio input , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x USB - mini-USB Type B
- Included Accessories
- Carrying case, remote control
- Cables Included
- 1 x mini-USB cable , 1 x HDMI cable
- Power Source
- AC / battery
- Voltage Required
- Run Time (Up To)
- 2 hour(s)
- 10.5 cm
- 10.5 cm
- 3.15 cm
- 270 g
- 5 °C
- 40 °C
- 15 - 85%
