Master every task in a crisp view
The Philips USB-C docking display for a comprehensive solution. View UltraClear 4K UHD and re-charge a laptop up to 90 W, all at the same time with a single USB-C cable. Pop-up webcam with Windows Hello delivers performance and convenience.
USB-C enables laptop power charging directly from a monitor
This Philips display features a built-in USB type-C docking station with power delivery. With intelligent and flexible power management, you can power charge your compatible laptop directly. Its slim, reversible USB-C connector allows for easy, one-cable docking. Simplify by connecting all your peripherals like keyboard, mouse and your RJ-45 Ethernet cable to the monitor's docking station. You can watch high-resolution video and transfer data at super-speed, while powering up and re-charging your notebook at the same time.
UltraClear 4K UHD (3840 x 2160) resolution for precision
These Philips displays utilise high-performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are a demanding professional requiring extremely detailed images for CAD solutions, a user of 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive.
IPS technology for full colours and wide viewing angles
IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle — even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
Securely sign in with pop-up webcam with Windows Hello™
Philips' innovative and secure webcam pops up when you need it and securely tucks back into the monitor when you are not using it. The webcam is also equipped with advanced sensors for Windows Hello™ facial recognition, which conveniently logs you into your Windows devices in less than 2 seconds, 3 times faster than a password.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
TUV Eye Comfort certified to reduce eye fatigue
Philips displays meet TUV Rheinland Eye Comfort standard to prevent eye strain caused by prolonged computer use. With TUV Eye Comfort certification, Philips displays ensure flicker-free, low-blue mode, no disturbing reflections, a wide viewing angle, less reduction of image quality from different angles and ergonomic stand designs for an ideal viewing experience. Keep your eyes healthy and boost work productivity.
PowerSensor saves up to 80% energy costs
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and then automatically reduces monitor brightness when then user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life
LightSensor for the perfect brightness with minimal power
LightSensor uses a smart sensor to adjust the picture brightness depending on the light conditions in the room for the perfect picture with minimal power usage.
Built-in RJ-45 Ethernet gives data security
EasyRead mode for a paper-like reading experience
This Philips display features a built-in USB type-C docking station with power delivery. With intelligent and flexible power management, you can power charge your compatible* laptop directly. Its slim, reversible USB-C connector allows for easy, one-cable docking. Simplify by connecting all your peripherals like keyboard, mouse and your RJ-45 Ethernet cable to the monitor's docking station. You can watch high resolution video and transfer data at a super-speed, while powering up and re-charging your notebook at the same time. -
UltraClear 4K UHD (3840x2160) resolution for precision
These Philips displays utilize high performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are demanding professional requiring extremely detailed images for CAD solutions, using 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive. -
IPS technology for full colors and wide viewing angles
IPS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle- even in 90 degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times. -
Philips display meet TUV Rheinland Eye Comfort standard to prevent eye strain caused by prolonged computer use. With TUV Eye Comfort certification, Philips displays ensure flicker-free, low blue mode, no disturbing reflections, wide viewing angle and less reduction of image quality from different angles and ergonomic stand designs for ideal viewing experience. Keep your eyes healthy and boost work productivity. -
LowBlue Mode for easy on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light. -
Less eye fatigue with Flicker-free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-free Technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. -
LightSensor uses a smart sensor to adjust the picture brightness depending on the room light conditions for the perfect picture with minimal power usage. -
PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life -
Designed to meet environmental standards
Designed for sustainability, and reduced operating costs, this monitor meets environmental standards. Such as: ENERGY STAR, EPEAT, TCO Certified.
 - Philips P-line 329P1H - LED monitor - 4K - 32"
 - LED-backlit LCD monitor - 32"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/399162
- Energy Class
 - Class G
- Energy Consumption per Year
 - 57 kWh
- Power Consumption (On mode)
 - 40 W
 - 2.0 megapixel camera, Gigabit Ethernet network adapter, USB 3.2 Gen 2 hub, USB PD 90 Watt
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
 - 0.18159 mm
- Brightness
 - 350 cd/m²
- Contrast Ratio
 - 1000:1 / 50000000:1 (dynamic)
- Response Time
 - 4 ms (grey-to-grey)
- Colour Support
 - 1.07 billion colours
- Colour Gamut
 - 117% NTSC (CIE 1976), 128% sRGB (CIE 1931), 89% Adobe RGB (CIE 1976)
- Input Connectors
 - 2xHDMI, DisplayPort, USB-C
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
 - AC 120/230 V (50/60 Hz)
 - Black texture
 - 71.4 cm x 28 cm x 64.9 cm
 - 12.2 kg
- Environmental Standards
 - TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
 - Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, CB, TUV Ergo, DDC/CI, RoHS, EPA, cETLus, CU-EAC, TUV Eye Comfort certified, EAEU RoHS
- Display Type
- Energy Class
 - Class G
 - 57 kWh
- Diagonal Size
 - 32"
- Viewable Size
 - 31.5"
- Built-in Devices
- USB Power Delivery
 - 90 Watt
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.18159 mm
- Pixel Per Inch
 - 140
- Brightness
 - 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
 - 23 - 75 Hz
- Horizontal Refresh Rate
 - 30 - 140 kHz
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - WLED
- OSD Languages
 - Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
 - Lead-free, SmartImage, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, Adaptive-Sync technology, EasyRead, Delta E<2 calibration, Windows 10 Hello, SmartControl
 - Black texture
 - 71.4 cm x 28 cm x 64.9 cm - with stand
 - 12.2 kg
Audio
 - Speakers - stereo
- Output Power / Channel
 - 5 Watt
 - DisplayPort 1.4 (HDCP 2.2) , 2 x HDMI (HDCP 2.2) , USB-C 3.2 Gen 2 upstream/DisplayPort Alt Mode (HDCP 2.2) , Audio line-out , Network , 3 x USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 downstream (fast charging)
Mechanical
- Tilt Angle
 - -5/+25
- Swivel Angle
 - 360
- Rotation Angle
 - 180
- Height Adjustment
 - 180 mm
- VESA Mounting Interface
 - 100 x 100 mm
- Cables Included
 - 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-C cable with USB-C to USB-A dongle
- MTBF
 - 70,000 hour(s)
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 40 W
- Power Consumption SDR (On mode)
 - 40 kWh/1000h
- Power Consumption (Typical)
 - 31.8 Watt
- Power Consumption Stand by
 - 0.3 Watt
 - 0 Watt
- On / Off Switch
- Included Software
 - Philips SmartControl
- Dimensions & Weight Details
 - With stand (highest position) - width: 71.4 cm - depth: 28 cm - height: 64.9 cm - weight: 12.2 kg , Without stand - width: 71.4 cm - depth: 6.2 cm - height: 42.2 cm - weight: 8.19 kg
- Shipping Width
 - 93 cm
- Shipping Depth
 - 18.6 cm
- Shipping Height
 - 56.3 cm
- Shipping Weight
 - 15.51 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
 - 8.0
 - 0 °C
 - 40 °C
 - 20 - 80%
