Philips Hue Impress Wide White & Colour Ambiance LED Smart Outdoor Wall Light Double Pack - designed for outdoors. Add colour to your outdoors with 2x Philips Hue Impress Smart Outdoor Wall Lights [Wide]. Simply install and enjoy 16 million colours to enhance the beauty of your outdoor space to create any ambiance you like. This Philips Hue outdoor smart light is specifically designed for outdoor environments and has undergone rigorous tests to ensure performance (IP44).
Highlight the beauty of your garden with the Philips Hue Lily 4x Smart Outdoor Spotlight Base Kit. This base unit includes 4x Lily spotlights, 40W power supply and all cables to start lighting your outdoors.
What's Required? - A Philips Hue Bridge (sold separately - see item number LJMJE) is required for smart control. Simply connect your Bridge, plug in your new Philips Hue lights and take advantage of smart outdoor lighting via the Philips Hue app.
Style with Colour - Choose from 16 million colours including warm to cool white light to create the perfect ambiance for relaxing or entertaining outdoors. Discover the perfect smart lighting for parties, BBQs and more!
Plug and Play - As part of the Philips Hue low voltage range, easily extend your smart lighting to cover your entire outdoor space without needing to call the electrician.
Control Lights With Your Voice - Works with Alexa, Google Assistant and Apple HomeKit devices for hands-free voice control. Control your smart outdoor lights with simple voice commands!
- Depth: 19 CM
- Height: 24 CM
- Width: 11.7 CM
Weather-proof (IP44)
This Philips Hue outdoor fixture is specially designed for use in outdoor environments for great performance. This lamp is designed with IP44: it is protected against water splashed from any direction. This product is ideal for general outdoor use. -
Easy to install and extend
Brighten up dark paths, create highlights in your landscaping or create a unique ambience on the patio. You can do it yourself, using Hue spots or bollards. The products are based on low voltage, and are safe to use and easy to install. No more complexity to get lighting outdoors: start to create and extend to suit your needs. -
High-quality aluminum and tempered glass
Philips uses high-quality aluminum and tempered glass to ensure advanced performance in outdoor conditions. As well as smart use of materials to optimize radio frequency. -
Control it your way
Connect your Philips Hue lights with the bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add the indoor switches to your system to change your lights. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Apple Homekit and the Google Assistant to allow you to control your lights with your voice. -
Unwind with warm to cool white light
Extend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax. From the warm white light of a summer sun, to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year. -
Decorate for the holidays with light
Holiday cheer starts here - with smart light! Use your Philips Hue lights to transform your home into a festive experience.
- Philips Hue White and Color Ambiance Impress - wall lamp - LED x 2 - 8 W - warm to cool white light - 2000-6500 K - black (pack of 2)
- Product Type
- Wall lamp
- Recommended For
- Balcony, garden, patio, porch
- Light Source Type
- 2 x LED
- Packaged Quantity
- 2 (specifications are for single item)
- Dimmer
- Black
- Wattage
- 8 W
- Energy Efficiency Class
- G
- Colour of Illumination
- Warm to cool white light
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 1180 lumens
- Intelligent Assistant
- Siri, Google Assistant, Alexa
- Platform
- Apple HomeKit, Hue
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
- Packaged Quantity
- Product Type
- Wall lamp
- Recommended For
- Dimmer
- Double insulated, weatherproof, wall mountable, outdoor usage, splashproof, dustproof, 16 million changeable colours, app-controlled, lighting schedules, power on/off timer, voice control
Light Source
- 2 x LED
- Built-in LED Lamp
- Wattage
- 8 W
- G
- 2000-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 1180 lumens
- Lifetime
- 25000 hours
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Compatible Application
- Philips Hue App
- Product Material
- Aluminium, tempered glass
- Body Colour
- Black
- IP44
- Warranty
- 2 years
- 19 cm
- 11.7 cm
- 24 cm
- 1.825 kg
