Philips Hue White Bulbs 4.2W GU10 6-Pack
Quicklinx: HXJ3WS00 Mfr#: 919313000401
Type: Light bulb
Compatible With: Alexa, Google Assistant
Hurry, only 1 left in stock!
£99.99 ex VAT
£119.98 inc VAT
Express delivery Order within the next 15 hours for delivery tomorrow
A perfect fit for spotlights, GU10 bulbs upgrade your home lighting. These bulbs are suitable for standard GU10 fittings and offer all the benefits of smart lighting.
  • Efficient illumination
    This light bulb delivers 400 lumens of brightness while consuming only 4.3 W of energy, ensuring effective and energy-efficient lighting.
  • Smart home integration
    Compatible with the Philips Hue Bridge, it allows for seamless integration into smart home systems, enhancing connectivity and control.
  • Flexible color temperature
    The adjustable color temperature ranges from warm to cool white light, providing options for various moods and activities.
  • Voice-controlled convenience
    Easily manage your lighting with voice commands through intelligent assistants, making daily operations simpler and hands-free.
  • Dimmable capabilities
    The dimmable feature allows users to adjust the brightness to suit different settings, promoting comfort and ambiance.
Philips Hue White ambiance - LED spot light bulb - GU10 - 4.3 W - warm to cool white light - 2200-6500 K (pack of 6)
Recommended For
Living room, bedroom
Light Source Type
LED spot light bulb
Packaged Quantity
6 (specifications are for single item)
Socket Type
GU10
Wattage
4.3 W
Energy Efficiency Class
E
Colour of Illumination
Warm to cool white light
Colour Temperature
2200-6500 K
Luminous Power
400 lumens
Dimmable
Intelligent Assistant
Google Assistant, Alexa - indirect
Communications Technology
Bluetooth, Zigbee
Packaged Quantity
Recommended For
Light Source
LED spot light bulb
Socket Type
GU10
Wattage
4.3 W
E
Energy Consumption per 1000h
5 kWh
Power Factor
0.5
Colour Temperature
2200-6500 K
Luminous Power
400 lumens
Dimmable
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Compatible Application
Philips Hue App
Supported Host Device Platform
iOS, Android
Bluetooth, Zigbee
Voice Controlled
Indirect
Warranty
2 years
5 cm
5 cm
5.8 cm
Diameter
50 mm
Length
58 mm
50 g
Type: Light bulb
Brand: Philips
