Philips Hue White and Colour Ambiance E27 Starter Kit with Bridge
Quicklinx: GX0JWS00 Mfr#: 929002468810
£108.33 ex VAT
£129.99 inc VAT
Add ambient colour to any room with the Philips Hue White and Colour Ambiance E27 Starter Kit. Connect to the included Hue Bridge to take advantage of the endless list of features. Control via the app, voice or any smart accessory.
What's in the box
  • Bridge
  • Ethernet network cable
  • 2x Hue bulbs
  • Power adapter
  • Be creative with colors
    Play with light and choose from 16 million colors to instantly change the look and atmosphere of your room. Set the scene effortlessly with one touch of a button. Use a favorite photo and relive that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger.
  • Sync with music and films
    Extend your TV viewing experience to the whole room or sync light to your favorite music and see how light reacts to the rhythm. Download the third-party apps and discover the amazing things you can do with Philips Hue.
  • Light up your gaming
    Lift your gaming experience to the next level. Download the third party apps and discover the amazing things you can do with Philips Hue.
  • Wake up and go to sleep
    Philips Hue will help get you out of bed the way you like to, helping you start your day feeling refreshed. The light brightness increases gradually, mimicking the effect of sunrise, and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep.
  • Create your ambiance
    Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of summer sun or the ice cool daylight of winter.
Philips Hue White and Color Ambiance Starter Kit - wireless lighting set - LED light bulb x 2 - shape: A60 - E27 - 11 W - RGB/warm to cool white light - 2000-6500 K - white
Wireless lighting set
Light Source Type
2 x LED light bulb
Supported Light Bulbs Qty
50
White
Shape
A60
Socket Type
E27
Wattage
11 W
Wattage Equivalent
75 W
Energy Efficiency Class
F
Colour of Illumination
Colour Temperature
2000-6500 K
Luminous Power
1100 lumens
Dimmable
Intelligent Assistant
Cortana, Google Assistant, Alexa - indirect
Platform
Apple HomeKit, Hue
Communications Technology
Bluetooth, Zigbee
AC 100 - 240 V
Frequency Required
50 - 60 Hz
50
Compatible with effects
Light Source
2 x LED light bulb
Shape
A60
Socket Type
E27
Wattage
11 W
Wattage Equivalent
75 W
F
Energy Consumption per 1000h
11 kWh
Power Factor
0.8
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Luminous Power
1100 lumens
Beam Angle Correspondence
Sphere (360°)
Warm-Up Time
0 sec
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
ZigBee technology, instant full light, Android compatible, iOS compatible, voice control, app-controlled, controlled via Bluetooth, dimmable with specific dimmers, mains light source (MLS), upgradable software
Power Requirements
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Power Consumption Stand by
0.5 Watt
Internet of Things (IoT)
Hub
Included
Hub Compatibility
Philips Hue Bridge
Platform
Apple HomeKit, Hue
Compatible Application
Philips Hue App
Supported Host Device Platform
iOS, Android
Bluetooth, Zigbee
Voice Controlled
Indirect
Body Colour
White
Power adapter, network cable, Hue bridge
Package
Box
IP20
Warranty
2 years / 30 days return
Dimensions & Weight Details
Hue bridge height: 2.6 cm x diameter: 8.8 cm , Light bulb height: 110 cm x diameter: 60 cm - 72 g
14.6 cm x 17.6 cm x 14 cm / 760 g
-10 °C
45 °C
Type: Wireless lighting set
Compatible With: Alexa
Compatible With: Cortana
Brand: Philips
