Philips Hue White and Colour Ambiance E27 Single Lamp
Quicklinx: DL2HWS00 Mfr#: 929001257303
Type: Light bulb
Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
£41.66 ex VAT
£49.99 inc VAT
  • Paint with light
    Play with light and choose from 16 million colors to match the light to your mood. Use a favorite photo and re-live that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger.
  • Sync light to music and films
    Extend your TV viewing experience to the whole room or lift your gaming experience to the next level. Turn any room into a dance floor and see how light reacts to your music.
  • Create your ambience
    Set the right ambience for any moment with beautiful, natural light. Set any shade of light, from cool energizing daylight to relaxing warm light. Take control and set the ambience. Not too bright., not too dark - just right.
  • Light for your well-being
    Light influences one's mood, behavior, alertness and routines. You can set the light that is optimal for your moment. Philips Hue helps you to energize, concentrate, read and relax. Customize your daily routines into moments you can enjoy.
  • Feel different, feel better
    Ease your sleeping routine and wake up gently for a fresh start each day. Philips Hue will help get you out of bed in a nice way. The gradually increasing light intensity gives you the feeling that you are waking up naturally with sunlight - rather than the rude awakening of an alarm ringing.
  • Away-from-home control
    You can control your lights remotely wherever you are. Check if you have forgotten to switch your lights off before you left your home, and switch them on if you are working late. With geofencing technology, your lights can even welcome you home or switch off automatically when you leave your home. It's all about simplifying your life and giving you peace of mind in smart and useful ways.
Philips Hue White and colour - LED light bulb
Light Bulb Type
LED light bulb
Shape
A19
Socket Type
E27
Wattage
10 W
Wattage Equivalent
60 W
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
800 lumens
Lighting Details
- 342 lumens , - 570 lumens , - 800 lumens , - 550 lumens
Beam Angle
160 degree(s)
Dimmable
AC 220 - 240 V
Remote controlled
Light Bulb
LED light bulb
Shape
A19
Socket Type
E27
Wattage
10 W
Wattage Equivalent
60 W
16 million colours
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Luminous Power
800 lumens
Luminous Efficacy
80 lm/W
Lighting Details
Beam Angle
160 degree(s)
Dimmable
Lifetime
25000 hours
Upgradable firmware, instant full light
Power Requirements
AC 220 - 240 V
Warranty
2 years
110 mm
Diameter
62 mm
Type: Light bulb
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Philips
Price Range Ex VAT: 0 - 50
